why was the light switch not removed? - the paint looks flat to me.. no hardner yet?
btw for brakes this is how I bleed them
make a bleed bottle (salmans jam etc with hole in the top lid and pipe in the jar or pipe just taped such that its dipped in the jar
get 2 paiti (aam ya keeno ki khaali paiti) place two high
use the rubber/plastic pipe of the jam setup and connect to brake bleeder screw - keep it higher than the hub assembly (prevents air from backing into the system
- open brake bleeder nipple
pump brake pedal very slowly for only half stroke (or normal stroke - do not pump to floor unless the master cylinder is brand new)
watch the brake bleeder jar after 5 strokes and keep the master cylinder full. Once you see clean brake fluid at the pipe - you are good on that wheel.
repeat on the rest 3 wheels.
DONE.
Takes 1 man only.
