Crank is OK - Block & head physicals are OK
I gave engine number to Toyota UAE (alfuttaim) with the pictures and findings of machine shop they recommended
-head rebuilt kit - 975 dirhams (complete with valves, seats seals & gaskits)
- machine shop asked for size 50 piston
-size 50 pistons with improved combustion curvature, ring, bearings set - 1200 dirhams
-cam & crank bearings set Toyota -700 dirhams
-Oil pump 275 dirhams
All Toyota stuff either from Thailand or Japan.
Purchased from al-futtaim spare parts shop, will be in hand by 11 PM tonight.
local market estimate cost for Japanes stuff not Toyota genuine approx 78000.00 less oil pump.
am not at all surprised with the findings of machine shop was keeping fingers crossed - and machine shop convinced me to believe driver's alibi "driver said while driving engine check light appeared & engine temp shot up so he pulled over and shut down engine checked for the radiator & belts before trying to restart then called mechanic he said 'timing' belt tot gai hai bring to work shop in morning" then i bring car by tow-chain to home us k baad ap agaya.
