I found some Regular & Daily basis Service Specifications SERVICE SPECIFICATIONS, LUBRICANTS for TLC (FJ-, BJ-, HJ-, 60 & 70 series) so sharing it with my friends & brothers, hope it helps you!
And a Request to Mods Make This Thread Sticky so everyone can take benefit from it
Vehicle: Toyota Land Cruiser (FJ-60, -62)
Engine model: 2F, 4.2L inline-6 cylinder gas-engine
Engine model: 3F, 4.0L inline-6 cylinder gas-engine
Fuel type: 91 RON unleaded, 90L
Engine oil, 2F: API SF, 8L (with oil filter change)
Engine oil, 3F: API SF, 7.8L (with oil filter change)
Coolant: Ethylene-glycol based, 16.5L
Manual transmission (model H41): API GL-4 or GL-5, SAE 90, 3.5L
Vehicle: Toyota Land Cruiser (BJ-60, BJ-70)
Engine model: 3B, 3.4L inline-4 cylinder diesel-engine
Fuel type: 40 cetane number, 90L
Engine oil: API CC, 6.7L (with oil filter change)
Coolant, BJ-60: Ethylene-glycol based, 13.3L
Coolant, BJ-70: Ethylene-glycol based, 13.8L
Manual transmission (model H55F): API GL-4 or GL-5, SAE 90, 4.9L
Vehicle: Toyota Land Cruiser (HJ-60, -61, -70 series)
Engine model: 2H, 4.0L inline-6 cylinder diesel-engine
Engine model: 12H-T, 4.0L inline-6 cylinder turbo diesel-engine
Engine oil, 2H: API CC, 10.7L (with oil filter change)
Engine oil, 12H-T: API CD, 10.7L (with oil filter change)
Coolant, HJ-60, -61: Ethylene-glycol based, 15.4L
Coolant, HJ-70: Ethylene-glycol based, 14.2L
Vehicle: Toyota Land Cruiser (FJ-60, -73, -75 series; BJ-60, -73, -75 series; HJ60, -75 series)
Transmission, manual (H41): API GL-4 or GL-5, 3.5L
Transmission, manual (H55): API GL-4 or GL-5, 4.9L
Transmission, automatic (A440F): ATF Dexron II, 15L (dry fill) or 5L (drain & refill)
Transfer case (with H41 or H55F): API GL-4 or GL-5, SAE 90, 2.2L
Transfer case (with A440F): API GL-4 or GL-5, SAE 90, 2.1L
Differential, front: API GL-5 hypoid gear oil, SAE 80w90, 3.0L
Differential, rear: API GL-5 hypoid gear oil, SAE 80w90, 2.5L (use LSD oil for LSDs)
Power take-off: API GL-4 or GL-5, SAE 90, 0.5L
Winch, mechanical: API GL-4, SAE 90, 0.3L
Winch, electrical: ATF type F, 2L
Steering gear housing: API GL-4, SAE 90, 0.63L
Power steering: ATF Dexron or Dexron-II, 0.81L (total) or 0.390L (tank only)
Steering knuckle: Molybdenum-disulfide lithium-base, NLGI-2
Steering link ends: Molybdenum-disulfide lithium-base, NLGI-2
Wheel bearing grease: Lithium-base multi-purpose, NLGI-2
Propeller shaft: Lithium-base multi-purpose, NLGI-2
Brake fluid: SAE F1703 or DOT-3
Vehicle: Toyota Land Cruiser (RJ-70, -73 series)
Engine model: 22R-E, 2.4L inline-4 cylinder gas-engine
Fuel type: 91 RON, 90L
Engine oil: API SG, 4.3L (with oil filter change)
Coolant: Ethylene-glycol based, 11L (with fr/rr heaters)
Transmission: API GL-4 or GL-5, 2.6L
Transfer case: API GL-4 or GL-5, SAE 90, 2.1L
Differentials, fr & rr: API GL-5, 1.98L & 1.85L
Power steering: ATF Dexron-II
Brake fluid: SAE J1703 or DOT-3
Vehicle: Toyota Land Cruiser (LJ-70, -73 series; KZJ-70, -73, -77 series; HZJ-70, 73, -75 series)
Engine model: 2L-T, 2.4L inline-4 cylinder turbo diesel-engine
Engine model: 1KZ-T, 3.0L inline-4 cylinder turbo diesel-engine
Engine model: 1HZ, 4.2L inline-6 cylinder diesel-engine
Fuel type: 48 cetane number, 90L
Engine oil, 2L-T: API CD, 6.7L (with oil filter change)
Engine oil, 1KZ-T: API CD, 8L (with oil filter change)
Engine oil, 1HZ: API CD, 9.5L (with oil filter change)
Coolant, 2L-T: Ethylene-glycol based, 11.5L (with fr/rr heaters)
Coolant, 1KZ-T: Ethylene-glycol based, 12L (with fr/rr heaters)
Coolant, 1HZ: Ethylene-glycol based, 11.6L (with fr/rr heaters)
Transmission, 2L-T & 1KZ-T: API GL-4 or GL-5, 3.0L
Transmission, 1HZ: API GL-4 or GL-5, 4.9L
Transfer case, 2L-T & 1KZ-T: API GL-4 or GL-5, SAE 90, 2.1L
Transfer case, 1HZ: API GL-4 or GL-5, SAE 90, 2.2L
Differentials (2L-T & 1KZ-T), fr & rr: API GL-5, 1.98L & 1.85L
Differentials (1HZ), fr & rr: API GL-5, 2.6L & 2.5L
If anyone have query other than this can ask without any hesitation i would love to help! :)
