Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Like Tree18Likes
Thread: 2jz-ge advice needed
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    Default 2jz-ge advice needed
    hey guys, I was planning to swap a 3ct in my fj. Due to its good mileage and sufficient power but as kabli 3ct are short in market and civil ones are in pathetic condition mostly I have changed my mind towards a 2jz-ge. I also considered 1g and 1jz but both seemed under powered..
    So I wanted to ask a few questions from people who have already done this experiment on a FJ 40
    1. What is its estimated cost (cost in pindi mithu khan is 75k for kabli)
    2. What is its approximate mileage per litre. (mechanics saying 8-9 kmpl which is kind of fine for me)
    3. Will i need to change differentials. I have stock ones. (some mechanics told me about differential change but i could not understand which diffs they want me to use.)
    4. Will it couple easily with my 5 fwd 4x4 gear box.
    I off road hardly once a month maybe. That too casually and not hard core. So off roading is not my main concern.
    You input will be highly appreciated.
    Drugs cause amnesia, and other things I can't remember
    qwertypoiu's Avatar
    Feb 2007
    29,136
    153 Post(s)
    3 Thread(s)
    so i guess Fj 40 2f engine not giving amazing mileage :p
    RIP
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    Quote Originally Posted by qwertypoiu View Post
    Not anymore. It gave amazing mileage though for 2 weeks not all happiness is permanent
    ShaMaaL's Avatar
    Jan 2012
    319
    4 Post(s)
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    Quote Originally Posted by ShaMaaL View Post
    bro yours was the first thread i read but it has some inconclusive information. some people even called 2jz as "death trap"
    ShaMaaL's Avatar
    Jan 2012
    319
    4 Post(s)
    Quote Originally Posted by Ravager View Post
    Pls check your inbox for my PM.
    fouadhafeez's Avatar
    Feb 2008
    Rawalpindi
    50
    2,698
    7
    3 Thread(s)
    I'm of the personal view that an engine does not turn a car into a death trap. People turn their car into one. Often, it is through neglect; by choosing to not upgrade or refurbish or revisit worn-out essentials like brakes and suspension, when they bung in a swanky new engine. Other times, it is by driving irresponsibly; endangering their lives, as well as those of others. So let me state: the 2JZ-GE (or GTE, for that matter) is NOT a death trap per se, on its own.
    Regarding the 2JZ-GE engine, it's a good powerplant which is smooth, offers good power, torque, and is reliable. In essence, though, it IS a 'car' engine at the end of the day...whose best application is for medium to large sedans.
    In off-roaders and SUVs, there is more of a requirement for lower-revving engines, which deliver peak power and torque at significantly lower revs. Since you're planning to use it in an FJ40, you probably have some reason why you want to replace a low-revving engine with a higher revving one. You probably also have a specific reason why you're choosing it over a 1FZ-FE (petrol) or a 1HZ (diesel) or a 1KZ (diesel); which are all better suited to SUVs.
    To answer your questions, to the best of my personal knowledge...
    1. Anywhere between 60-85K is about the going price for a 2JZ-GE. This depends on the condition and vintage of the engine and should include the transmission, airflow, wiring, and ECU etc. A lot of 2JZs are advertised as "Kabli" but are actually, rejects from cars that have been fitted with other engines. Careful scrutiny of this aspect is warranted.
    2. It's a 3000 cc engine, which you'll be using to drive a Land Cruiser. You'd be lucky to get 8-9 kmpl.
    3. You don't NEED to change the differentials, in the sense that it's not a must. You might want to consider this aspect that the 2JZ (mostly used in Crowns and other large sedans), drives a very different sort of diff, from the heavy, immensely-robust FJ40 one. Most people choose to swap diffs too, so as to upgrade them, at the time of engine swap. 60 or 80 series Land Cruiser diffs, and Nissan Patrol diffs are popular choices, in this regard.
    4. In essence, pretty much any engine can be coupled to any transmission. A lot of people have already done this, in some CJs. I've also heard news about this swap (2JZ with manual tranny) being performed in a Hilux, although I have no real evidence of this.
    If you have any further specific questions, feel free to ask. Best of luck.
    Always buy cars which your children love. They'll be helpful allies against your wife, later on!
    Feb 2008
    Rawalpindi
    50
    2,698
    7
    3 Thread(s)
    One last thing..."power figures" are immensely misleading, and often have more to do with self-satisfaction / bragging rights, than anything else. The application of the powerplant - and its intended use - is the most important aspect to keep in mind when going about an engine swap.
    To illustrate this, my biggest car (a ten foot tall, four door FJ40) has a 4200 cc diesel engine which puts out 130 hp, and is comfortable at 2000 rpm. My smallest car (a tiny, two seater MR2) on the other hand, has a 1600 cc supercharged petrol engine which puts out 145 hp...and is always at its happiest near the redline.
    Different applications. Different needs. And different ways to address them.
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    Thank you sir for the detailed reply.. It was really helpful... I want to go for diesel too but the initial investment is too big.. Drive and power are not an issue here as the original 2f engine has a pretty strong ride.. But sadly the petrol figures make me think twice before taking it out for a spin.
    I saw a few fjs with 1g engine and their owners were satisfied with the ride.. But i wonder how a 2L engine can pull this giant vehicle.
    Sent from my C6603 using Tapatalk 2
    taimoorkhan's Avatar
    Jan 2004
    33
    583
    10 Post(s)
    ive had 3ct and 1g engines both in my cj5s. Although both of the engines were OK for a short chasis vehicle such as a CJ5 but wont recommend for a fj40.
    Currently i drive a rkr with its original engine that is the mighty 3F and most of the time either my fuel tank is empty or my pocket. As per my limited knowledge and experience ill recommend that u go for the 5vz which is 3400c petrol engine out of a prado, considerably torqish and a little lighter on fuel. it gives around 8km/l in a frnds fj70.
    last weekend the price was 90k.
    Hope this helps
    Regards
    1)Merdcedes W124-Daily driven, 2)Toyota FJ70 RKR-Reliable offroader, 3)Mitsubishi Pajero Shogun-Comfy workshorse, 4)M38A1-Fun ride, 5)Daewoo Racer- Econimically reliable
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    Quote Originally Posted by taimoorkhan View Post
    Hope this helps
    Regards
    i have decided to go for 1jz. Getting one in 60k.. Non vti. Will install after market turbo if need be.. lets see how this goes
  12. #12
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    a gud swap in fj for a daily runner n no offroading ! lacks torque ! gives u rnd 7 to 8 kmpl
    v mated it wid gearbox of 2L diesel engine ! although the clutch wuz kinda weak for it ! used clutch assembly of same 2L gear !
    diffs u need of fj nt bj ! as its a petrol engine !
  13. #13
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    Quote Originally Posted by salmanrasheedpsh View Post
    i have diffs of FJ will be using 5fwd genuine land cruiser gear with it. Was thinking about getting surf Diffs. Will give better mileage and higher speed.
  14. #14
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    original diff if in gud condition r as strong as dey get n last a lyf tym dun change em but yes it cant handle speeds beyond 150 ! whteva u do it , it just doesnt go beyond dat
    the jeep i mentioned runs a 1uz wid 1hd gear box nw
  15. #15
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    2LTE gear is 5 gear original of 70 series landcruiser/prado !
  16. #16
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    if it 2jzge can be mated wid gear box of 1HD , datz a charming gearbox ! ulll need to make custom housing !
    n yes i wuz wrong , used 3ct clutch in 2L gearbox wid 2jz engine
  17. #17
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    1jz is finalised... Paid token money.. Getting everything done in 90k.. Includes labor and all extra parts that go with the engine..
  18. #18
    Jan 2011
    Peshawar
    1,709
    22 Post(s)
    Which gear ?
  19. #19
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    Which gear ?
    5 forward gear of land cruiser
  20. #20
    kambrit's Avatar
    Aug 2005
    Southend-on-Sea
    40
    2,423
    23 Post(s)
    I have been told by mechanic in Lahore having this engine with Pardo 1994 gear box auto with 4x4 cost is 140000rs
    Is that right?
    Engine it's own is 80000rs.
    Caz am changing in mine too.
