I am fitting 45 engine onto cycle .
Its mounts are made to be fitted this way :(foto below) (as u my see the V shaped mount holds it as the carburator has a base which i levelled with the ground , meaning no tilt.
Now ,the place where i am mounting engine on rear of bicycle (due to position requirement of chain) engine will be positioned like in the photo below and carburator will be titled :(foto below)
(It will obviously cause problem in working as carburator will be titled ??)
Now,
Ab agar woh piece jo carburator or engine ko jorta hai , usjo ulta lga du and phir us per carburator lgaon to carburator balance/level ho jata hai (foto below)
QUESTION 1 :
KIYA IS CONNECTOR KO ULTA KERNAY SAY ENGINE KI PERFORMANCE PER FARQ PARAY GA ?
QUESTION 2:
IS ENGINE POSITION MEI SILENCER CONNECTOR OPER KI TARAF HO JATA HAI , IS SAY ENGINE PER KIYA FARQ PARAY GA ?
(PROJECT DETAIL LINK: https://www.pakwheels.com/forums/general-motorcycle-discussion/272845-guidance-needed-fitting-engine-bicycle )
Sent from my QMobile Z10 using PW Forums mobile app
