Page 1 of 5 123 ... LastLast
Results 1 to 20 of 88
Like Tree24Likes
Thread: Guidance needed for fitting engine to bicycle
    mtokeyboard's Avatar
    Mar 2012
    137
    Default Guidance needed for fitting engine to bicycle
    Dear brothers , your help and guidance is needed in fitting the engine to cycle.
    It is a 45cc chinese engine, avaialable from neela gunbad lahore in rs 6000. It has a clutch and a race as controls.
    Made for cycles, there are too clamps for fitting onto rods nears pedals of cycle.
    Now the problem is that i dont have much space in my little cycle onto which i wish to fit it.
    1.please guide me bt how to fit it on the carrier (or by removing the carrier)
    2. If i fit engine by rotating it , such that its plug faces towards uppet side instead of facing to the front , will ot cause provlem in engine working ??
    3. If i wield additions rods after removing carrier will they tolerate weight of 10 kg of engine ?
    Thanks bhaiyoGuidance Needed fitting cycleengine to cycle  -1683022Guidance Needed fitting cycleengine to cycle  -1683023Guidance Needed fitting cycleengine to cycle  -1683024Guidance Needed fitting cycleengine to cycle  -1683025Guidance Needed fitting cycleengine to cycle  -1683026Guidance Needed fitting cycleengine to cycle  -1683030
    Mar 2012
    137
    Engine kisi bhi position mei fit ho , it will perform ??
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    Quote Originally Posted by mtokeyboard View Post
    Where you think to fit the engine?
    Vertical engine will be fit vertical means in standing position.
    There's a lot of cutting welding you need but it will be fun
    Best of Luck
    The first step towards knowledge is to know that we are "IGNORANT"
    The first step towards knowledge is to know that WE are IGNORANT
    Mar 2012
    137
    I plan to fit engine at the rear end, by removing carrier, making a mouting with rods that holds engine.
    Sent from my QMobile Z10 using PW Forums mobile app
    Mar 2012
    137
    Quote Originally Posted by Hassan1991 View Post
    Best of Luck
    In this position of engine that i have planned (above post), the carburator will be facing toward the ground almost. Will it affect the working of engine ?
    (This position is necessary so that the chain for wheel may be adjusted with the engine )
    huzaifa2k9's Avatar
    Mar 2015
    103
    Can you please provide specs of this engine(power)?
    Sent from my HTC One_M8 using PW Forums mobile app
    Mar 2012
    137
    Quote Originally Posted by huzaifa2k9 View Post
    2 stroke 45cc
    Pedalling start engine
    Clutch,
    Race
    No gear changer
    Rs 6000
    I havent started it yet.
    Just confused about making its mount.
    Mar 2012
    137
    I just found on aliexpress.com
    That a pull start assembly is available for it for rs1200 !
    and i have also found a video regarding its assembling at youtube ,by BIKEBERRY
    Mar 2012
    137
    Best of Luck
    Yes , good idea about cutting off the susoension rods and wielding seat directly to the base rod. I hope it doesnt damage the frame strength !!will measure the dimensions if engine coukd fit by cutting those rods.
    Also, i found out that once carburator is facing ground it will cause spillage of fuel so my previous idea of mountig it upside down (by removing carrier) fails now.
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    Float valve inside the carb will not work right if it's not placed perpendicular means in standing position
    Place the engine on the rear in vertical position carb
    But every pump will directly effect the engine like a person feel when he sit on the carrier you should make strong mounts
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    Guidance needed for fitting engine to bicycle - aa77c2fafb51db5e93dd55a9e43eac77
    Placing at the first position is easy you can weld bars and make mounts
    While placing engine at second position is difficult you have to cut frame and it's being difficult to weld straight and it will not look good.
  12. #12
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Always wanted to do that people call me mad I dropped the idea
    Btw what about brakes? Are you going to upgrade that
    second bicycle have very short gear ratio you will have to get bigger sprockets
  13. #13
    Mar 2012
    137
    You are right.!! rear mouting will give good looks to cycle too. I shall upload photos of the problems i am facing with rear mounting
  14. #14
    Mar 2012
    137
    Quote Originally Posted by saboor73 View Post
    then i shall have to switch to disc brakes which are available for cycles.
    And its top speed goes to upto 50km/hour i have heard which is enough for a cycle,,, perhaps !
  15. #15
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    Installing disc on rear is another problem you have to make the threat "churi" on the rims to install disc.
  16. #16
    Mar 2012
    137
    Default Carburator positioning help
    I am fitting 45 engine onto cycle .
    Its mounts are made to be fitted this way foto below) (as u my see the V shaped mount holds it as the carburator has a base which i levelled with the ground , meaning no tilt.
    Guidance needed for fitting engine to bicycle - db02409569e4d8324c49b26598df3beb
    Now ,the place where i am mounting engine on rear of bicycle (due to position requirement of chain) engine will be positioned like in the photo below and carburator will be titled foto below)
    (It will obviously cause problem in working as carburator will be titled ??)
    Guidance needed for fitting engine to bicycle - 5ad39a3f6e6c635190998556fb542e27
    Now,
    Ab agar woh piece jo carburator or engine ko jorta hai , usjo ulta lga du and phir us per carburator lgaon to carburator balance/level ho jata hai (foto below)
    Guidance needed for fitting engine to bicycle - 1241beb4cd275cd56c7c496ad73d606f
    QUESTION 1 :
    KIYA IS CONNECTOR KO ULTA KERNAY SAY ENGINE KI PERFORMANCE PER FARQ PARAY GA ?
    QUESTION 2:
    IS ENGINE POSITION MEI SILENCER CONNECTOR OPER KI TARAF HO JATA HAI , IS SAY ENGINE PER KIYA FARQ PARAY GA ?
    (PROJECT DETAIL LINK: https://www.pakwheels.com/forums/gen...engine-bicycle )
  17. #17
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    Nae connector or ulta lagana sa kuch nae hoo ga lakin carb should be straight
    Guidance needed for fitting engine to bicycle - 419322767cfcd5e36cf0e165b7830b7c
    Your thinking like this?
  18. #18
    Mar 2012
    137
    Right ..! Good ho gya yeh to !!
    Haan engine isi tarah lgana hai , mager pichla rod thora pechay ker kay lgana hai dusri side per chain kay liay gunjayesh aye
  19. #19
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    Right....and I'm confused about mounts,does they came with engine or you had to made them?
  20. #20
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    What about fuel tank ?
