Page 1 of 16 12311 ... LastLast
Results 1 to 20 of 303
Like Tree299Likes
Thread: Club 500
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Cool Club 500
    Asalam U Alikum,
    Friends Club 500 thread is for all those who love Bikes, Safety Gadget, Modifications etc.. Being a owner of GS 500 I tried to put all info that i have in my mind & experience that i have wth 500..
    My Traveling Experience with GS 500:
    Well Worlds Best bike in 90s as it was the king & Road Master of its time no dough long as well as short trip give u really comfort at 1st place. My 1st Long tour on 500 is to AJK for 3 days. Really its fun for me & enjoyed a lot on Highway as well as on narrow roads, Sharp turn, Mud, Water, Rocky road etc
    Plus Points:
    No Problem On long run ( even u ride continuous 8 hr)
    Good Grip
    Easy Break
    No Heat Up ( As it is Air Cooled)
    Neg Points:
    Change Handel If u wanna go Long rides its sport edition so have to bear it...
    Don't be smart in MUD..other wise
    Fuel Consumption :
    I am getting 25 @ long & at local 22
    GS500 Manual :
    You can print it really informative.....
    http://www.motorkari.cz/upload/files...ser-manual.pdf
    OIL CHANGE:
    http://gstwin.com/oil_change.htm
    Genuine Suzuki Parts Prices : (Est.)
    Oil Filter = 470/-
    Air Filter = 2400/-
    Disk Pad = 4119/-(Rear) 5671/- (Front)
    Chain Sprocket Set = 17140/-
    Clutch Lever = 750/-
    Break Lever = 750/-
    Tyre Rear + Front Dunlop = 34500/-
    Clutch Cable = 1850/-
    Excelerator Cable = 2440/-
    Battery 11amp Liquid = 3800/- Dry = 1800/-
    Maintenance Schedule
    Club 500 -1186256
    • Initial Service
      • Tighten cylinder nuts and exhaust bolts
      • Inspect valve clearance, adjust if necessary
      • Inspect all fuel lines for leakage
      • (California models) Inspect evaporation canister and vapor lines
      • Change engine oil and replace filter
      • Check engine idle speed; adjust to 1200 rpm if necessary
      • Check clutch adjustment; adjust if necessary
      • Check drive chain tension; adjust if necessary
      • Inspect all brake hoses for leakage
      • Check brake fluid levels in both master cylinders; add fluid if necessary
      • Check brake pad wear
      • Inspect tire condition and air pressure
      • Check steering operation; adjust if necessary
      • Check operation of front forks
      • Check rear suspension operation
      • Check all chassis bolts and nuts for tightness; tighten if necessary
    • Every 600 miles (1000km)
      • Clean & Lube Chain
      • Check Oil level. The distance from Low to Full on the Dipstick is approximately 1 pint (0.6 litres)
      • Check Tire Pressure (33psi Front & 36psi Rear)
    • Every 2000 miles (3000km)
      • Clean & inspect air filter
    • Every 4000 miles (6000km)
      • Check battery electrolyte level and condition
      • Inspect spark plugs; regap or replace if necessary
      • Tighten cylinder head nuts and exhaust pipe bolts
      • Inspect valve clearance; adjust if necessary
      • Inspect all fuel lines for deterioration and leakage
      • Inspect all brake hoses for chaffing, cracks or leakage
      • Check all cable adjustments; adjust if necessary
      • Check throttle grip operation, play and adjustment
      • Check headlight aim, adjust if necessary
      • Check front and rear brake light switch operation
      • Lubricate rear suspension linkage and swing arm bearings
    • Every 7500 miles (12000km)
      • Replace spark plugs
      • Replace Air Filter element
      • Synchronize carburetors
      • Check operation of front brake
      • Check front fork seals for leakage
      • Check rear shock absorber for leakage, looseness or damage. From forum post: "Push on the tail of the bike, and listen to hear if it sounds like the shock is sucking in air. Pay attention to how fast the shock compresses, and how it rebounds - if it feels like it shoots back like a spring, you have a failed shock. If it comes back in a somewhat controlled manor, the stock shock is probably okay. If it overshoots and bounces around a bit, definitely bad shock."
      • Check rear suspension linkage for looseness or damage
      • Inspect tires for excessive wear, cuts or other damage
      • Check wheel rims for damage
      • Inspect drive chain guide for wear
      • Check break pedal height
      • Check center stand for looseness or damage
      • Check side stand for looseness or damage
    • Every 2 years
      • Change Brake Fluid
    • Every 4 years
      • Replace all brake hoses
      • Replace all fuel lines
    FOR PARTS
    Suzuki Gs500 F (usa) parts list partsmanual partsfiche
    Suzuki GS500 Parts & Accessories - Parts N More - Japanese Vintage Motorcycle Parts[page]=3
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Awesome (Y)
    Dream is not that which you see while sleeping it is something that does not let you sleep.
    gorkan's Avatar
    Feb 2008
    35
    787
    21 Post(s)
    hopefully I am going to be a part of this club soon. seeking any help or advice from experienced riders
    “Have you ever noticed? Anybody going slower than you is an idiot, and anyone going faster than you is a maniac”
    usmanuetian's Avatar
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    Waaahh...
    Leave sooner, drive slower, live longer
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    After Getting it ....2 main issue that i face is
    1). Disk Break Front
    2). Balancing of wheels.
    As i used to drive smooth rides before that so not like this too much...But its engine & power hooks me up to get this ASAP....
    So went to my Old mechanic whom i know when i have CD 70 in 98... He is good chap & also expert having much knowledge abt bikes He check bike & say WELLDONE .... at that time i was surprised that he don't ride it but I am happy....
    I go with little check ups & then disk pads...Balancing...now bike is back in action...
    I tried to go only @ 180 on it on highway till now...Bec is kay bad SIGNAL aha jata hy... I found very un comfortable @ 120...why...this is ?
    I went back to Mechanic tell him the situation ..then U know what he tell...A MONO SHOCK is making trouble so very much dangerous @ high speed....So good to know that he also have solution ....After changing that MONO SHOCK back in action...now much more comfortable @ 120 ...
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by r1 View Post
    Awesome (Y)
    Thx r1...
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by gorkan View Post
    U r welcome... waiting to see u on 500...
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Am making a deal of GS500. Offered 190k to a guy but he is asking 220k. Lets see if he agree else i would get a 2000 Yamaha XT600.
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Quote Originally Posted by d3vil View Post
    InshAllah will meet yo soon in Isalamabad. I know you have imported some safety stuff. If possible kindly PM me you cell no. and iam also planning to go for either GS500E or new RP. Till then i hope i can be apart from club 500
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Quote Originally Posted by Silver_Knife View Post
    What would be the price of new RP?
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    @@@...MISSION DETAILING...@@@
    U know guys i love detailing bec it give mentally satisfaction.. & i know guys on Forum CRAZY abt it... It will add beauty & new look to you toys......
    Some Pic already on Forum but add Here also....
    Club 500 -1169899Club 500 -1169900Club 500 -1169901Club 500 -1169902Club 500 -1169903Club 500 -1169904Club 500 -1169905Club 500 -1169906Club 500 -1169907Club 500 -1169908
  12. #12
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Good..Good... Hope to see u on GS.. any ways I also have Trail also Suzuki TS185 little bit knowledge for it but XT is monster if its in POWER. BOL
  13. #13
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    U r welcome brother....Yes Safety is must Will share some pic...Yr comments & suggestion are always welcome brother ...yes u can enjoy this FILM before interval........
  14. #14
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    @@...SAFETY GADGETS...@@
    1). Shoes
    2). Protection Gloves (Summer)
    3). Protection Gloves (Winter)
    4). Body Armour (In case u don't wear full suit)
    5). Protection Jacket (Fully protected ,Arm , Shoulders, Full Back)
    6). Protection Trouser (Fully Protected , Nee, Thia, Hips )7
    7). Tea Shirt.
    8). Separate Nee Protector
    Total Package cost me abt 20k .
    I am not shore about rain bec...Its has been written on it but haven't try it so water proof is not yet tested....
    Enjoy some pics... Will add some more Gadgets on next pay...
    Club 500 -1170237Club 500 -1170238Club 500 -1170239Club 500 -1170240Club 500 -1170241Club 500 -1170242Club 500 -1170243Club 500 -1170244Club 500 -1170245Club 500 -1170246Club 500 -1170247Club 500 -1170249Club 500 -1170250Club 500 -1170251Club 500 -1170252
  15. #15
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Club 500 -1170254Club 500 -1170255Club 500 -1170256Club 500 -1170257Club 500 -1170259Club 500 -1170260Club 500 -1170261
  16. #16
    arsi_mast's Avatar
    Jan 2009
    25
    228
    3 Post(s)
    Nice kits...
    @r1 what is the price of xt600???
  17. #17
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    Quote Originally Posted by arsi_mast View Post
    Nice kits...
    Well Dont know abt exact price in Pakistan but 2000 model started from $ 800 up to $ 2500 ...Its better then DRZ very much dominate in its time on DRZ...
  18. #18
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Nice kits...
    170k..
  19. #19
    d3vil's Avatar
    Dec 2007
    1,950
    5
    44 Post(s)
    3 Thread(s)
    170k..
    @r1 can u share some pics...
  20. #20
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Give me some days my cameras are out of town and i can't take pics from my Nokia 1112
Tags for this Thread
