Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By hidalgo
  • 2 Post By vickytulla
Thread: Need to Pool up people for Engine(110 or 125 ) impots from China for cHonda
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Default Need to Pool up people for Engine(110 or 125 ) impots from China for cHonda
    AOA,
    Hope you all are doing well.
    this thread is started after seeing mouth watering 150/200/250 cc water cooled engines being imported by @vickytulla and others for their Ravi RP125 .
    https://www.pakwheels.com/forums/non...ahore-pakistan
    though we the 70cc cHonda Lot could also enjoy upgraded quality engines.
    i need to pool people for it because importer will only import if we place an order of 12 engines.
    Lifan China is one of the biggest and best engine manafacturer in manafacturing small sized engines.
    they make 110/125cc proper engines (not just a 70 on steroid... i.e. bigger cylinder ) .. having proper matching gear ratios,clutch,valves,etc.
    Price for 125 cc horizontal engine fit to chonda body with carb cdi was 18-20k pkr total.
    if someone is interested please mention here.. in which one you are interested (110 or 125 ) so that we can pool and order those engines and give an upgrade and new life to your aging cHondas.
    these will be simple air cooled engines like our existing one but with much power. and life to it.
    for 125 below is best bike
    Lifan 1P54FMI
    https://www.pakwheels.com/forums/gen...da#post4845923
    Regards
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    i want 125 cc one..
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Nice initiative but search local market ..you know hathi k dant khanay k aur dikhany k aur
    legend will revive soon
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    I can put a little more detail to help you @asjdsm ...
    1 - upto 110cc non racing engines are readily available in market already and price is from 20k to 28K depending upon quality and accessories with it (carb/cdi/rectifier e.t.c...)
    2 - For 125cc non racing engine you will have to import.
    3 - For 125,140,150,160,180cc sports type variants which fit bolt on to Chondas the price can be higher then what you mentioned.
    All the above mentioned engines not only have bigger pistons, but also have bigger crank, weight, Reduction ration, Clutch, gear ratio, and for racing variants most of them are Liquid (Oil) Cold with higher compression ratios
    Some Pictures or non racing 110~125, Oil Coled, water cooled, 150~140~180~200, and 4 valve racing engines which can be sourced.
    (I think you should add these to main post):
    Need to Pool up people for Engine110 or 125  impots from China for cHonda -1592699
    Need to Pool up people for Engine110 or 125  impots from China for cHonda -1592700
    Need to Pool up people for Engine110 or 125  impots from China for cHonda -1592701
    Need to Pool up people for Engine110 or 125  impots from China for cHonda -1592702
    Need to Pool up people for Engine110 or 125  impots from China for cHonda -1592703
    Need to Pool up people for Engine110 or 125  impots from China for cHonda -1592704
    Need to Pool up people for Engine110 or 125  impots from China for cHonda -1592705
    Need to Pool up people for Engine110 or 125  impots from China for cHonda -1592706
    Need to Pool up people for Engine110 or 125  impots from China for cHonda -1592707
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    for 125 cc below are best
    LIFAN 125cc 1P54FMI with below specs
    -4 gears all up. kick start.. using same bore stroke ratio as ybr and piston is same as used in suzukis..
    so hopefully it wont have any parts issue.
    Engine Model: Lifan 1P54FMI-125cc
    Type: 4-Stroke single-cylinder OHC air cooled
    Bore & Stroke: 54 X 54mm
    Compression ratio: 9.47:1
    Displacement: 123.7cc
    Max. HP: 8.72 HP @ 7,500 RPM
    Max. Torque: 8.0N.m @ 5,500 RPM
    Carburetor: Walbro, Mikuni, or Sheng Wey
    Idle: 1,500 RPM
    Starter: Kick Start
    Spark plug: A7TC or NGK C6HSA
    Plug Gap: .28 or 0.6-0.8mm
    Ignition system: CDI (Capacitive Discharge Ignition)
    Lubrication: Pressure / Splash
    Oil capacity: .9L (15w/40-SE)
    Measurements: 18 1/4" x 11" x 11"
    Weight: 44.1/4 lbs (Engine only) Shipped 52lbs
    Clutch: auto or manual clutch-wet
    Gears: 4 speed (primary reduction: 3.722 manual, 4.059 Auto)
    Gear Ratios: 2.833/1.706/1.238/0.958
    Magneto: Permanent magnetic
    Voltage: 12 Volt
    This engine has a three disc crank mounted heavy duty manual clutch. The head has a large domed combustion chamber with large valves. The intake valve is 27mm exhaust valve is 23mm.
    This engine must be a neutral to start with a kick starter
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by vickytulla View Post
    let us keep it simple ..
    so option 2 is best..
    for option 1 : these used engines 110cc cost 8-12k and most have slipped threads .. and dented parts.. inside parts are wielded .. i checked at autorace rwp and their best build one was using wielded gears .. .or those whose gear tooth were having bits flown off of them and they had polished that .. so no quality..
    i do not want to make a monster out of this little 70 .. i have used altered bike and found 110-124 cc to be most convinent size for these frames..
    Newbie Follow
    digirads.2's Avatar
    Oct 2016
    Do you still have engines, I need one 70, 100 or 110cc
    Please let me know
    Thanks
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by digirads.2 View Post
    Please let me know
    Thanks
    I Haven't bought new one yet. And looking for 110/125cc horizontal engine .
    We would have to import at least 5 items of same model so need to pool buyers.
    @vickytulla
    Sent from my Nexus 5 using Tapatalk
