Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By VCheng
Thread: What are the reasons behind petrol leaking from Breather tube of Carburetor?
    mohsinwahhab's Avatar
    Jul 2013
    26
    1,133
    19 Post(s)
    Default What are the reasons behind petrol leaking from Breather tube of Carburetor?
    Petrol is leaking from my GS150 carb breather hole which causes bad fuel average (only 30 Km/l) i checked float height from two different method
    1: Clear tube method
    2: Ruler
    Float height is accurate and bike is not doing missing,hiccups e.t.c ,spark Plug colour is light brown. I clean the carburetor twice and clean every jet and hole thoroughly but when i touch the breather hole my finger become wet due to petrol.Expert members help me.
    what are the reasons behind petrol leaking from Breather tube of Carburetor???? -1635528what are the reasons behind petrol leaking from Breather tube of Carburetor???? -1635529what are the reasons behind petrol leaking from Breather tube of Carburetor???? -1635531what are the reasons behind petrol leaking from Breather tube of Carburetor???? -1635532
    VCheng's Avatar
    May 2010
    Select City
    25,475
    7
    434 Post(s)
    4 Thread(s)
    Is the needle valve sticking? The float and the needle valve have to operate smoothly to function properly in addition to the correct float level.
    Jul 2013
    26
    1,133
    19 Post(s)
    sir if needle valve stuck and does not sit properly so why petrol is not leaking from float bowl drain hole and only leaking from carb vent hole?
    Quote Originally Posted by VCheng View Post
    VCheng's Avatar
    May 2010
    Select City
    25,475
    7
    434 Post(s)
    4 Thread(s)
    Quote Originally Posted by mohsinwahhab View Post
    Is that drain hole clear of sediment? The carburetor needs a thorough cleaning and rebuild, which is an easy job if done right. Do you have access to compressed air?
    Jul 2013
    26
    1,133
    19 Post(s)
    carb drain hole is clear i checked it today sometimes when i touched the drain hole with my finger one or two drops of petrol is leaked and sometimes i touched it and nothing happened and yes i have access to air compressor.
    VCheng's Avatar
    May 2010
    Select City
    25,475
    7
    434 Post(s)
    4 Thread(s)
    Get a complete rebuild kit, take the whole thing apart, clean and blow out everything meticulously and re-assemble with new service parts.
