remove the bulbs, put the headlamp in direct sunlight to let the water evaporate. Seal it with silicone along the edges, then put a couple of SILICA gel packs in the housing away from direct view. it will soak up the moisture building afterwards. Do perform the last step cause no matter how much u get it sealed, water will still get in.
