Hi All!
Car - Honda Civic 2005 VTi
Odo Reading - 88k kilometers
Symptoms - upon sudden acceleration, upon RPM reaching around 5k, the car misfires, stutters (as if in a limp mode), loses power and eventually shuts down with a check engine light.
Error code - Plugging into the mechanic's scanner, the code generated was "TDC Sensor (1) Noise"
Queries
1- Will changing the crank sensor fix it?
2- What causes it to fail? What was done wrong so it can be avoided.
Thanks in advance.
Here is a photo of a cat for those who help.
Click here to go to the SOLUTION
