Page 1 of 7 123 ... LastLast
Results 1 to 20 of 140
Like Tree4Likes
Thread: suzuki liana tip/maintenance thread
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Default suzuki liana tip/maintenance thread
    I have decided to start this thread as this car is very badnam of having hard maintain car which I don't think is right so I have started this thread to help every liana owner facing any type of problem is his car
    error codes suzuki liana in link below
    suzuki liana error codes
    suggstion/tip/solution to every cng problem with suzuki liana
    solution to every cng problem of suzuki liana
    The coil burning problem
    solution to coil burning problem
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    some error code of suzuki liana
    P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
    P0451 - Evaporative Emission Control System Pressure Sensor Range/Performance
    P0452 - Evaporative Emission Control System Pressure Sensor Low Input
    P0102 - mass or volume air flow circuit high input
    P0742 - torque converter clutch circuit stuck on
    P0722 - stands for output speed sensor
    p0717 - is for transmission turbine speed sensor
    salahuddin99's Avatar
    Jul 2008
    26
    99
    @saboor
    bhaii kindly help my liana is dead from last week.its check engine light is blinking.some times car start sometimes not.it pretends to start on first crank but after that it just simply rotates
    today i check by opening fuel supply at engine end when i switch the car little amount of fuel supplied and it stopped after that.
    PASSIONATE drives))))))red city n silver corolla)((((fly on union star 70
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by salahuddin99 View Post
    @saboor
    how did you checked fuel supple does car sound like toon toon before getting off????? your car have cng ??????? if yes then local or ff
    Jul 2008
    26
    99
    no toon toon sound.simply i turn on the ignition and pull out the fuel supply pipe connecting to rail.yes local cng
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    does car start on cng?????????
    Jul 2008
    26
    99
    no car is not starting on cng
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    does your car need to be started on petrol before converting to cng like ff cng does
    Jul 2008
    26
    99
    yes first it starts on petrol then goes to cng.
    bro i want to enquire is this any immobilizer thing issue or just fuel system not working
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    bro it your fuel supple issue if it was immbolizer issue your car woudn't have cranncked in simple word"chabi goomti magar self nai leti"
    Jul 2008
    26
    99
    when i took out the fuel pipe when switch is on it just through little bit amount of fuel.....
    and bro what about the check engine light blinking
  12. #12
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    bro if check light is blinking then I can say that your fuel pump is weak injector are not getting sufficient fuel engine need your ecu is giving you a warning that the amount of fuel which needed to start the car is not being supplied by blinking light the only thing I would suggest you to 3S and then tell them to check your fuel pump
  13. #13
    Jul 2008
    26
    99
    is there any way to start the car because its dead
  14. #14
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    sadly no
  15. #15
    Jul 2008
    26
    99
    ok dear thnx alot for your support i will visit 3s and see what happens next.........
  16. #16
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    blinking check light usually indicates the immobiliser is active - your key is bad, just like the old suzuki baleno had.
  17. #17
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    If it key than why car starts some time and then shut why fuel supple is not constant ???????????
  18. #18
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    the key is dying or the immobiliser antenna is malfunctioning, thats why it sometimes works and sometimes does not.
  19. #19
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    I didn't understand this if it was a bad key car would crank mean self will work engine will start then key work is over key wouldn't send signal to shut of car and bhai plz try that miita kate chney wala pan method to explain as I am phatan in understanding things
  20. #20
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    the immobiliser in liana will allow the starter to crank as its a fully analog circuit leading from key to starter, however the ECU is intercepted with immobiliser and it will not fire the injectors, coils or even allow the fuel pump to run if the immobiliser is active.
    if your car is having random start issues with blinking check light then its time to have the key and immobiliser unit tested as they are failing.
