Page 1 of 5 123 ... LastLast
Results 1 to 20 of 95
Like Tree30Likes
Thread: QG18DE rebuild project
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    785
    55 Post(s)
    2 Thread(s)
    Default QG18DE rebuild project
    As we all know sometimes scrappies hand you 100k km plus engines that deteriorate with certain passage of time. And sometimes engines are good too. Depends on how you know about things. My engine was good but, issue i faced was timing adjuster broke on the way to muree once i somehow managed to reach muree and then came back. This thing brought valve missing in my car.
    Due to timing mismatch, the cams weren't provided with oil flow so they seized Slightly.
    I was somehow dragging the car.
    And it's compression dropped to 140-120-130-138
    Anyhow i planned for working on it and was saving for it.
    My estimated expenditures were around 15-20k
    But they slightly exceeded because people from engineering works set there own rates.
    When the head was lifted up, it appeared a cylinder 2-3 were cross. Head gasket was blown.
    And when inlet valves of 1 cylinder were meant to be opened the contrasting inlet valves of cylinder 2 were to be closed but they were left open.
    I built the head, valves grinding done, seats were replaced so were the tapets, gats and valve stem seals.
    Second issue was smoke, what we saw was almost all pistons were dancing inside the block when they were moved left right. Good rings and pistons never allow this dancing of pistons.
    Anyhows i bought new cams from mushtaq. They were 10/10 cams, i pulled them from a head mushtaq had in his go down also with cam caps.
    Gave him 2500 rs.
    Then i was in a hope he'd be having pistons or a good block assembly but both the things were unavailable. The block's he had were corroded.
    So now finding the Rings was the headache. Kiyani autos said a big no for 80mm rings. The one he had were 82mm but the top ring was very thin, which my mechanic said is inappropriate.
    Anyhow after a slight struggle we know the secret about the Rings, lol which I'll release to the person having this project done. As I've done research on this myself. As when you'll go finding QG18de rings, you'll hear a big no from everyone.
    Moreover the piston pins were loose too and causing loud tak tak sounds while revving the car.
    So pins were changed too.
    Gasket was made of carbon sheet.
    To cut the story short built it very nicely mashallah.
    25k were spent nicely to get almost a new engine.
    Now the engine is on running process. As my mechanic strictly told me not to rev or heat it until 1500-2000km.
    Alhamdulilah all was done good and quality parts were added up to the engine.
    So here goes the whole project.
    So guys don't worry QG18de can be built too.
    Mashallah getting 190-195psi pressure on all cylinders.
    Project consumed 2 days.
    Saturday Sunday night the car was ready.
    Contact me for queries. 03455072961
    STYLISH BOYZZZ STYLISH ATTITUDE
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    520
    14 Post(s)
    Keep it up @dani_kk zra insanon ki tarah chalaya kar k har waqt mechanic ki shakal na dekhni pare :-D
    Sent from my Z12 using Tapatalk
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Thinner rings = less frictional losses
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Bore look look smooth
    I hope this pic is beforing honing
    QG18DE rebuild project - 1681018d1462264730 qg18de rebuild project 1462264417425
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    SHare Honing Procedure , Bore Measurement , Piston/Wall Clearance Along With Break-In Procedure...
    You Install New Piston Rings Of Which Brand??? Share COST Also
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    And pls also spill the beans on qg18 rings 😀
    https://www.facebook.com/OsamaAbbasPhotography
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    785
    55 Post(s)
    2 Thread(s)
    Bro thing is this whole process involved, Profesional mechanics and special engineering works people.
    I can't share this information, it's kind of a business secret of those guys. They said get us whoever wants this work done. We will charge them.
    Gasket is made from carbon sheet. Can hold the heat of even v6 engines.
    And @QamarAhmadawan hahaha apko pta hai mera, samjhnay walay din paida hi nai hua QG18de ko sukoon se kesay chalaon khudi btayen bus 2000km tak sahara karha hun.
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    785
    55 Post(s)
    2 Thread(s)
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    785
    55 Post(s)
    2 Thread(s)
    Yes the cylinders were smooth and fine.
    Piston pin was loose, and ring was too loose.
    So surface of block that is attached with head was faced by some rough material which I've no idea, maybe a circle sand paper.
    Mashallah the compression is very good.
    And I've straight downpipe with 3 exhaust free flow so now exhaust is telling that someone is banging me
    The one banging the exhaust is engine
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    785
    55 Post(s)
    2 Thread(s)
    Cost of rings was 4000
    Cost on head was around 13-14k
    And piston pins were for 4000
    Mechanic labour was 5k
    Gasket 2500
    Cams cost was 2500 they were 10/10
    And one more thing i removed the inlet valves. There were some throttle type valves for economy controlled by a pss. It wasn't working, and in fact blocking the air in so removed them.
    The car after 2000km would be ready to literally nail.
    Any 1.8 dohc car.
    My challenge is open to all categories till 1.8 na engines. And no lsd, no nos, no slicks.
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    785
    55 Post(s)
    2 Thread(s)
    That was the blown head gasket, i was shocked how with this gasket the car was even touching 150kph?
  12. #12
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    785
    55 Post(s)
    2 Thread(s)
    And guys about the honing process, i was unable to gather videos and picture that time.
    Guys had great knowledge about head.
    One was bore specialist one was head specialist. Bore specialist only inserted and took out the pins. Pins used are not stock pins they've a double layer. Seem very strong to me.
    And another modification is coming soon.
    That is custom inlet with big piping and bigger 50+ mm throttle body and aluminum or steel exhaust headers would be installed. Waiting for savings now.
  13. #13
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Btw the rings secret is that piston rings of one Toyota engine fits qg18de pistons
  14. #14
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by dani_kk View Post
    umm - so V6 engines produce more heat?
    Nissan use MLS headgasket on this engine because its very long life and evenly controls the temperature of the engine
    and what about the head bolts - did you replace them?
    overhauling Nissan QG engines is not any rocket science, they are bread and butter modern style engines with thinner piston rings and large valve poppets just like your average toyota AR and AZ engines or Mazda L3 etc - what trade secrets are you talking about??
    I hope your machinist followed the Nissan specified piston/wall clearance, it is very large and results in a loose piston when installing. It evens out and goes proper once the engine reaches 90C even temperature all around (under 5 minutes)
  15. #15
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Gasket 2500
    Any 1.8 dohc car.
    No New Pistons?? In Above Post You Just Mention Pistons Were Literally Rattling Inside Bore.....How Come You Use Same Pistons With New Bore/Hone Procedure??? WHat Was Piston Vs Cylinder Wall Clearance ?
  16. #16
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    There Is No Business Secret In Rebuilds B.t.w
    Its Written And Is For Sale Across World To Be Read By Person Who Rebuild Or Wanna Rebuild.....Someone Saying So Lives In Fools Paradise...
  17. #17
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    520
    14 Post(s)
    @Xulfiqar
  18. #18
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    785
    55 Post(s)
    2 Thread(s)
    Well to be honest, i never said bore has been widened.
    Same bore is used. Pistons were rattling because of piston pins. They are replaced and pistons are washed up.
    Rings used are of 4af Toyota engine. And the top ring of QG's are not thin. It had the solid steel ring. As xulfiqar said it's not rocket science in building this engine, he is right. . If and only if the owner of car has some knowledge. If he is dumb he'll be looted. And soon the engine will tell them what is called rebuilding a QG.
    And yes i was just increasing the curiosity of the post @Ser bro.
    Therfore i play alot with nissan's so not an issue for me to rebuild this engine.
  19. #19
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    785
    55 Post(s)
    2 Thread(s)
    Rings were 90x4mm.
    These rings were balanced accordingly.
    And pistons were released after they were wearing the Rings.
  20. #20
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    785
    55 Post(s)
    2 Thread(s)
    Valves were grinded, honing done new seats installed, cultus gats were installed.
    Stem seals are new.
