@All
I was on the lookout for spark plugs and although testdriver had mentioned a plug code, I still researched a bit at my end and here is the NGK's Europe website that helps you identify the compatible plug code.
Also, while i was at their US website, I sent out a question to their technical support team and here is what they sent to me. Just thought I'd share it with others so that its helpful for them:
Info@ngksparkplugs.com
Date: Wed, May 13, 2009 at 8:04 PM
Subject: RE: NGK Form Mail
To: "hayee.bhatti@gmail.com" hayee.bhatti@gmail.com
Hello,
Thank you for contacting NGK USA. Unfortunately the Racer model is not listed because it was never sold here in the USA. I was able to find the application listed in NGK Europe's information and it shows the recommended replacement plug to be the BPR5ES stock# 7422. With CNG you will want to drop one heat range colder and use a high ignitability plug such as our iridium IX series plug. The compatible part number is BPR6EIX stock# 6637. You could also use the single platinum version BPR6EGP stock# 7084 Hope this helps, thank you.
Regards,
Brandon Peeler
Technical Support Representative
Aftermarket Division
NGK Spark Plugs (U.S.A.), INC.
46929 Magellan Dr.
Wixom, MI 48393
http://my.artoffast.com/NGKTECH
-----Original Message-----
From: hayee.bhatti@gmail.com [mailto:hayee.bhatti@gmail.com]
Sent: Wednesday, May 13, 2009 12:51 AM
To: Info
Subject: NGK Form Mail
**** Contact Form & Tech Info Feedback ****
Email From: hayee.bhatti@gmail.com
VehicleType: Car
Make: Daewoo
Model: Racer
Year: 1993
Engine Type: 1.5 Standard
Comments: I own a Daewoo Racer 1993 model with a stock 1.5 (1498cc petrol) engine and manual transmission.
http://en.wikipedia.org/wiki/Daewoo_Nexia
It has also Compressed natural gas setup (landirenzo) in it and car is majorly run on CNG. I look forward to install NGK plugs in it but cant decide which specific one to install. Even the part finder on your website doesn't have this model listed and the closest Daewoo nubira 1999 model has a different engine setup. Can you please suggest me various plugs (just like the part finder result page suggests various kind of plugs that can fit). Let me know if you need any further info.
When: 5/13/2009 12:51:02 AM
