Hi Guys,
Firstly I'd like to thank all Pakwheelers for all the great advices i've had over the years (speically for the Suzuki Khyber threads in this site from which I have taken a great deal of help in maintaining my khyber over the years)
I am facing a delimma to buy 1 ton or 1.5 ton. Brand already decided; to choose from Mitsubishi Heavy Industries (MHI) or Mr.Slim
My room is recently shifted to upper story, the room faces constant sun light from roof and the Kitchen is below this room. The room was pleasent in winters but since summers its unbearable and no human can dare sleep in it since the bed, the chairs, the sofa and everything emmitts heat and you would wakeup exhausted in the middle of the night breathless and dehydrated! The room temprature is 30-35 even at night.
The background of the story is that I had bought a 1 ton/12K BTU GREE a/c and it sucked big time now I have read a lot every where and I have a hunch to buy 1 ton but I am really afraid and don’t want to waste my money if I later find out that the a/c is below capacity. I want an a/c that can take room temprature down from 35 to 19 in my current room. However experts say if A/C is bigger than required capacity it will quickly cool but not dehumidify and the room will be damp (my room's humidity measured with a meter is 80)
· Capability: Temprature down from 29(starting temp) to 26 in the span of 7 hours of sleep
· Room size: 12ftx13ft and 9.5ft high, Covered by all 4 sides and on the ground floor
· Outer installed in a duct (10x5 feet and 20 feet high), placed 1.5 feet away from adjucent wall
· Power cable = 7/36 Pakistan Cable from panel to socket and 7/52 from pole to meter and meter to panel
· Voltage = 210-230v (Volt meter in panel and in main hall so I notice all the time)
· Ampereage meter shows full amperes they should be.
· The A/C sent twice to GREE Company, gas refills and other minor repair but no use and I gave up on this piece of machienery
Also I would like to know the inverter based model of Mr.Slim and MHI and their prices in both 1 and 1.5 ton capacity.
Also I need to know where to get that vaccum pump thing for installation and what are the benefits compared to normal desi installation.
Also is the 3.5K original kit worth it or any 1.5 K kit would do?
Also would a 3 kVA stabilizer suffice since the rating is 2.25 kVA or should I get a 4kVA stabalizer (I have already pre-decided to go for a servo motor and preferebly stabmatic or any foreign brand)
I Apologize for making you read 469 words J
