@Xulfiqar
My Axio driven 120,000 kms. Knocking starts after the car is driven 5 Kms or more... After cold start there is no knocking till almost first 5 Kms... After that acceleration is normal... Knocking only occurs when the car gains some speed and rpm drops to near 1100... If accelerator is pressed...rpm goes up and knocking disappears...
I've changed air filter, oil and oil filter, cleaned throttle body... Replaced coolant. CVT oil also replaced with the correct procedure and Toyota original CVT oil TC.fuel filter and pump also replaced recently
Previously there was some thick oil in the engine and there was no knocking but I replaced it as soon as I bought the car. now I've put in shell helix HX-7... No CEL is on and scanner shows no pending codes....
Is it due to timing over advanced when rpm drops and knocking is caused???? Is the oil too thin for the age of the engine and oil pressure gets low?? Plz comment on this issue... Coz engine otherwise is perfect and there's water in the exhaust and no oil or carbon... Acceleration and consumption is also good. Only the knocking is bothering...
