yeah you are right we can use smaller engine instead of this bigger engine ,,,,,,,,,many years before i started similar project but wont complete it because of shortage of time ,,,,,,,,,,,,,,a guy written above that this engine can deliever 23Hp at 1500 RPM , may be he is right ,,,,,,,,and acording to my calculation this alternator need 17 to 18 HP engine at 3600 RMP ,,,,,,,,,,,,means this engine is more than enough for this alternator,,,,,,,,,,,,cultus engine can gave 48 HP at 5100 RPM ,,,,,,,,,,,,we can also use that as well,,,,,,,,,,,i plan to use F8B engine and add a gear system in between engine fly wheel and alternator,,,,,,,,,,,suzuki bolan gear box can also be used or we can use pullys/belt system,,,,,,,,,,,although this pully and belt system is old fashion and may be not too reliable but still can do the job,,,,,,,,,,,,,,,,but dear i suggest not to go for that system,,,,,,,,,,,,,,,,if you need 10 Kw generator then batter buy two 6.5Kw generators,,,,,,,,,,,,,,these 2 generators combine repair/maintance and fuel cost will be lower than this giant,,,,,,,,,,,its not suitable for home use but very good from commercial purpose,,,,,,,,,,,,,,,,
