Your saying that unichip didn't solve the knocking issue?Then how come they are claiming that they can solve it
Do let us kno if that is the case. I woudnt mind getting an early delivery.
they are still making a lot of money by selling adulterated super and hioctane, yesterday they were supposed to reduce the fuel price but Govt. want to pocket more tax.
i had unichip, pros its quicker and torquier than stock 1.5T cons u cant drive in knocking issue. Recently i got reflash to eliminate knocking.
Unichip and reflash are two different product from Unichip Pak. Unichip give power/torque but wont solve the knocking problem unless u get the ecu reflash.
has any one else noticed the highlighted buttons in the pic to be of very low quality. can they be changed, r they available in gud quality?
Welcome to Honda Atlas Pakistan 🇵🇰 bro
So reflashing solved the issue of knock?as in 100% or still there are issues?also does getting it reflashed voids the warranty?
the VSA update atlas honda is doing has nothing to do with ticking/knocking issue.. it is affecting some cars where electronic parking brake is not engaged when applied after turning ignition off.
Civic X Safety Recall VSA Update
ML.REAASC6A.RECALL2016_CIVIC_VSA_SOFTWARE_UPDATE_SB16-090__KC6_.pdf (128.0 KB Honda Service Bulletin)
sorry if already discussed in thread.
Yes so far no knocking, i dont think it will void warranty.
How can you say that? Any authentication or rumer?
Honda Civic 2017 Caught Fire
Honda Civic X 2017 caught fire due to after market low quality electric wiring with HIDs,
Ku ky .mai ny khd full payment start my hi kr di thee december 2016 my is promise ky saath ky aik do mahinay pehly gari mil jai gi.....tentative date thi 29th april 2017.....aor abhee tak to nai aai
Phir tu apko 2% jurmana den gy Honda Atlas for each month and if not than you should go to consumer court.
Making the final payment early will not effect you car's delivery in any way...(at least in my experience)...The only way to get car early is if you have a reference.......
Last couple of days, have seen two cars burnt. Can these be attributed to the after market fittings?
Not sure
Most probably as the civic burned was fitted with Drls and HID the blasters were quit visible in bonnet
I booked Oriel on 26th Oct with full payment and received on 8th March. Tentative delivery was 31st March
There is a function AC On and AC Off. I observed that when you run on some set temperature let say 20 with AC on/off disabled you have less cooling but then turn AC on by pressing button and you will have more cooling.
