Dear all, Kingly give your point of view and share your knowledge regarding the LM Motorbike 4T 10W-40 Street (((SYNTHETIC)) and Motorbike 4T 20W-50 Street ((MINERAL)) Which one is better for SUZUKI GS 150 and why?
10W40 is recomended grade for suzuki GS150.and i will aslo recomend you to go for 10W40.becasue 10W40 is thin oil with better fuel economy and acceleration as well as performance.it make less wear and tear to engine.also its semi syntehtic so it has more life then mineral 20w50.so all in all i always recomend 10w40 since bike is new.
Thank you for the reply, can u plz also inform me about the interval b/w oil change?? after how many kms should i change this oil ?? my byke is only 10,000 km old...
oh you already drove 10000 kms.if you drove all on 20w50 then 10w40 is not recommended.becasue while 20w50 made enough wear the 10w40 will not work well.regarding.oil interval it depends on the oil brand.the Zic should not be drove more than 1000-1200 kms.and the other low priced should be even used at for less interval.while Liqui moly is able to work good for atleast 1500-2500 kms (company life is 5000 kms)
I have only use it(20w50) twice ,other wise i was strictly using Suzuki's 10w40 oil. So what do to say now? should i go for 10w40 or 20w50???
hmmm if you used suzuki genuine oil which is (10w40)then you can go for 10w40.
bro if you used suzuki genuin oil more time than 20w50 then its ok you can go with 10w40.and @tintin1. brother i am using Liqui moly 10w40 in my ybr 125 since first oil change and its serving me well and i have driven almost 12000 kms.and i have taken the interval from 3000 kms to 2000 but best result last till max 2500.
Go for kendall 10w40 oil with liquid titanium and additives
Success Is A Mindset.
Engine oil grade to be used according to the engine life; i mean in new vehicle it is recommended to use 10w40 but not after 20,000 or in old engines.
Sent from my SM-G920F using PW Forums mobile app
I am using 10w40 LM and I am changing it on 3000km and still usable for more 1000km according to mechanic it can use more 1000km
Sent from my SM-N910G using PW Forums mobile app
Air cooled engine hein sb. So if u ver using 10-40. Then keep sticking to it. Till it dosent smokes out. Or reduces. Don't change ur brand so offten. Every oil has its own protective layer. Which can b dangerous on changing. An expert apprised me in a way that one should not change the brand grade b ager change kerney hein tou same brand mei raho... Either wise search for the best match in other brands.
FOr new bikes LM 10-40For Old Bikes More then 20000KM LM 20-50I am using LM 20-50 And drain it after 2000KMs My bike Gs 150 2012 model and run more then 20K KMsI am satisfied with it
@aks_e_ahmed @aks_e_ahmed
10000 (ten thousands) km driven YBR is taken as new bike or old bike???
???? where did u get this info??i m pretty sure its incorrect.
do u even know what 10w-40 means? or 20w-50
Use 10W40 because GS engine is OHC (over head cam) that,s why company has recommended A thin oil 10w40 for itthin oil lubricate+flows more frequently than a thick
Always Use synthetic oils because synthetic oils are far far better than minerals
@hamikhan kesay hen aap ???
11000km driven bike mien 10W40 dalna chahiye k ni??
winters bhi hen abhi
pehly bhi 2 baar 10w40 use kiya hy lakin baki baar 20W50 he use kiya hy dost ne bike is YBR
