The ignition System is totally bypassed,if you put the key in ignition system and try to start the engine then nothing will happen however i inserted a key and cut off its head to permanently unlock the steering. It kills the fuel system if someone attempts to tamper,try to cut any wire, try to remove this system or try to break this system, meanwhile during this tempering process your two way communication remote keep bugging you with sound and it has a range of 500 meter. I personally checked it with 200 meter on a straight road.
