Day 4 Continues:
After almost 90 mins drive we reached Tattu. Its a small village not much facilities are available there. Next stop was Fairy Meadows (H), Once all jeeps arrived we started the trek. This is the hardest and most beautiful trek i have done till date. Because i was too slow
and i stopped at many places to take pictures, it took more than 4 Hours
to Complete the trek. If you are experienced trekker or you have good stamina you can complete the trek in Max 3 hours.
Advice: When you are starting the trek make sure you have penalty of water with you as first half of trek is hot, but second half is quite cold so also make sure you are dressed appropriately. One more thing wear comfortable shoes which have good grip avoid flat sole shoes. You can hire porters at Tattu, they will charge you 800-1000 for 20KG.
After midway there are 2-3 points fresh water springs from where you can refill your water bottles. Water of these springs are very clean and refreshing. After midway there is a shortcut (w.r.t to distance) its short but its harder than the original trek and can take more time. But i would recommend you take the shortcut as its more scenic specially after mid day.
Following are some pics of the trek.
Killer mountain
Its some kind of fungus
