dear gurus Will 6.5 inch wide rims and 195 profile tires fit in suzuki margallah without rubbing issue?
i think rubbing issue hoga
having 1 in khyber..working great...wont be an issue
pics would help u to find a potential buyer.
this is how it looked after putting them on.
how can i attach pics here?
go advance ,,, there will be a paper clip sign aka attachments ,,, attach pix from there
khuda ka wasta
diameter should not bigger than orginal tire/rim dia of car.
195 / ?/15 should fit, i dont know the ? figure to answer correctly
195/50/15 is just 1mm more in diameter than 175/70/13 which is the original size for Margalla and Baleno e.t.c.
I also have 195/50/15 in my Baleno.
depends on offset of rims, if too much either way, they'll rub either on the outer fender (body) or the inner engine bay side of the wheel well..
ooops my bad i missed the 50 written on top.
should be ok. 50 is pretty low profile
i like your avatar ^^ but i know its not you
