I have fuel consumption issue with 5A-FE engine. 1992 Corolla AE100
Manual transmission 5 speed
No check engine light or error codes
symptoms:
high fuel consumption. 8kmpl in low traffic, 10-12kmpl in long distance. without AC, light foot
idle warm engine - showing water steam out from tail pipe, accelerate - slight black smoke, cold start faint blue/black smoke present while pickup. no noticeable smoke after warm up and cruising
Tested:
Coolant temperature sensor (0.3V at 90C)
MAP sensor (3.6V at not running engine, 1.5V at idle)
TPS VTA-E2 600-Ohm when throttle closed, E2-IDL - on
Oxygen sensor - no any voltage detected even at fully warm and 2500rpm - replaced
Thermostat installed
Engine cold start around 1000rpm, warm idle settled around 700rpm.
PCV valve cleaned. there was some oil inside throttle body
Fuel pump recently replaced (no effect on fuel consumption)
engine oil - 4mm level dropped from H level for around 2000km
New oxygen sensor installed. but engine running rich.
Oxygen sensor read 0.9V continuously while engine over 2000rpm
connect T1-E1 in diagnostic port and VF1 voltage continuously 5V while keeping engine 2500rpm. no 8-10 times fluctuate as manual say.
Tried with heated oxygen sensor - same result as 1 wire sensor even at idle.
if I increase engine to over 3000 and then release throttle quickly, sensor reading dropping to 0.2V range that means O2 sensors are working well and respond to lean condition.
O2 sensor showing that engine running rich even at idle.
I tried disconnect each injector power connector at idle and every time engine slowing down equally.
Fuel pressure regulator not tested. but no change in engine if I stop vacuum hose
ECU inspected for faulty capacitors or other faults - not found.
what should I check?
Can be leaking injector(s) ?
or fuel pressure regulator ?
