Tuning Menu
1992 Nissan 300ZX
Owner Ted Shimizu
Hometown Highland, CA
Occupation homeland security operations
:DPower 394hp, 359lb-ft with 91-octane fuel and 15psi boost; 505hp, 457lb-ft with C16 and 21psi of boost
:PEngine 3.0 liter VG30DETT with GReddy TD05-16G turbos, SUS manifolds, downpipes, Type-S blow-off valves, external wastegates, radiator cap, 15R two-row front-mount intercooler, Profec E-01 boost controller, SP-2 exhaust, hard pipes; Unorthodox Racing pulleys; Hi-Overdrive water pump pulley; A’PEXi dual-cone intake; Selin Design dual-MAF sensor translator; Walbro 255lph fuel pump; 555cc Nismo injectors; Specialty Z 2.5" test pipes; B&M Super Cooler; Howe Racing radiator; Nismo thermostat; NGK spark plugs; Optima Red Top battery; HKS silicone couplers; Nismo oil filler cap; Powertrix grounding kit
:)Drivetrain five-speed manual transmission swap from Specialty Z; Concept Z Performance driveshaft; Specialty Z Max Street clutch and RPS flywheel
:)Engine Management OEM ECU with Specialty Z software flash
Footwork & Chassis HKS Hipermax II springs; Stillen 28mm front and 21mm rear sway bars; Suspension Techniques end-links; Cusco rear strut bar; Noltec front camber control arms; Kazama Auto tension rods; Border Racing seven-point rollcage; alignment by DriftSpeed
:)Brakes Endless six-piston front calipers with 13.58" rotors, stainless lines and EP952 pads; Brembo rear rotors; Motul fluid
(H)Wheels & Tires 18x9" Yokohama Super Advan SA3R wheels with black centers and red lips; 235/40R18 front Hankook Ventus K102 tires and 275/35R18 rear Hankook V12 Evo tires; KICS 30mm rear
:)Exterior rear fenders widened 2"; ’99 JDM rear center panel; shaved rear wiper; Bomex BM type 2 front bumper; Wings West Type W side skirts molded to body; Varis rear bumper molded to body; AbFlug rear diffuser; Veilside Combat II Drag rear spoiler; Bomex Type 1 mirrors; Border Racing hood; Nissan JDM fender side and taillights; Powertrix carbon foglight ducts; Catz 4300K HIDs; OE Toyota Camry Constellation Lavender blue metallic pearl paint
:)Interior Recaro Speed seats with Wedge Engineering brackets, GReddy harnesses and Type NB shift knob; Veilside steering wheel; custom dash by Mr. K; Concept Z Performance gauge rings; Stillen gauge panel; custom glovebox gauge panel; two Innovate Motorsports XD-16 wideband 02 gauges; GReddy 52mm boost, 60mm oil pressure gauges; GReddy Intelligent Informeter; turbo timer
Audio Alpine IVA-D300 head unit; 12" Rockford Fosgate Punch sub; Jensen PS260 amp
