1993 Mitsubishi 3000GT VR4
Twin Turbo, All Wheel Drive, All Wheel Steering, Active Aero Dynamics.
Exteriors
Custom Paintjob in Camel Racing Yellow & Ebony Black
Angel Eye Headlights with 6000k Xenon
Smoked Out Tail Lamps, Parking Lights, Corner Lamps and Fog Lights
Hood Pins & Lock
18"x7.5" Front, 18"x8.5" Rear, Matt Black Multispoke Wheel with Steel Lip
Tires Front Yokohama AVS Sport Front 245/45/ZR18, Rear 255/45/ZR18
Interiors
Performance
400-450bhp on stock ECU & Injectors (Current Setup)
500-550bhp with AEM ECU and 750cc Injectors
The entire suspension and drivetrain has been overhauled. Engine completely rebuilt from scratch.
Samco Silicon Hose Kit
Polyurethane Engine Mountings
Kevlar Timing Belt
Custom Imported Aluminum Crank Pulley
Spec Stage 4 600ft/lb Clutch
Fidanza Flywheel & Adjustable Cam Gears
Ross Forged Pistons
Clevite Piston Rings & Bearings
Pauter Connecting Rods
Custom Aluminum Fuel Rails
Aquamist Water Injection
Walbro 255lbs Fuel Pump
RC 750cc Fuel Injectors
AEM Fuel Pressure Regulator
Greddy Profec E01 Boost Controller
AEM Map Sensor 3.5 Bar & Wideband O2
AEM Standalone Engine Management System
Hawk Performance Brake Pads
Twin Turbos TD04-15G Custom Built Xecutioners
