Well total cost was round about 35000. If you are going for only rebuild it costs around 25000 to 30000 . The mechanic charged 9000 .The qabli thermostat valve 650 new clutch was around 12000 but i just repaired mine for 1500 one qabli clutch bearing 500 . Changed the transmission oil for 500
Also changed the brake pads and had some work done on the axles as well. Head resurface cost around 2900 and the rebore cost 3200. Didn't change the valves only bought new valve seals .as mechanic said that they were okay. Piston were Taiwanese and the rings were japan made .
