what is approximate quantity of oil reduced at 3000 km. please mention volume. dipstick is just a tool to identify oil level high / low in engine, not oil quantity. - over fill will be high low is for lower then recommended quantity signaling 'add more'
check for PCV valve functioning.
as you mentioned the high mileage and oil grade there is no harm to continue using the same grade oil. compression test is best way to find out if there is something wrong in engine
