Alhamdulillah. It has been very good for being 18 years old.
It was used by the embassy here so in good condition and maintained well.
Issues I've had so far:
Starter stopped starting the engine randomly. It ended up being the solenoid. Found one in Bilal ganj, has been fine since then.
Brake Accumulator chirp noise. A common fault and I have just decided to order through parts central. Expensive, but worth it.
A/c cooling fan stopped working. Removed and took it to Bilal ganj. They fit an xli corolla motor in it. Seems fine so far.
Axle boot torn. Replaced. But this is just normal wear and tear.
The rest has just been maintenance. Air filters around 3000 per for Malaysian, 6000 for genuine. I've been using Malaysian so far so good. Diesel filters im using genuine. 4500 each, replacing every 10k.
When I bought it, trans fluid was due. Could only find a supplier on daraz. Sp-iii mitsubishi genuine fluid for 3000 per liter. Changed and it shifts like butter.
I think the key is I do about 85% of the work myself as I do not trust local mechanics. I did this in Canada too.
So far alhamdulillah, it's been a great machine.
