Tuning Menu
2000 Honda Civic CX
Owner Loreto Garcia
Hometown San Jose, Ca
Occupation Student
Power 186hp/134lb-ft (before Skunk2 Racing valvetrain)
:PEngine 1997 Honda 1.8L B18C1; Ported and polished cylinder head by DNR Performance; Skunk2 Pro Series Stage 1 camshafts; Black Series cam gears, dual valve springs, retainers; 68mm Pro Series throttle-body (port-matched); Pro Series intake manifold, Black Series oil cap; VTEC solenoid cover, cam seal, battery tie-down, billet wire cover and radiator hoses; Supertech valves; ARP head studs and rod bolts; Engine block girdle; Hasport black billet engine mounts; AEM short ram air intake and adjustable fuel pressure regulator; JDM 98-spec ITR exhaust manifold; DNR custom turndown exhaust; Benen Industries exhaust manifold heatshield w/Mr. Metric hardware; Walbro fuel pump; Russell -6AN lines and inline fuel filter; Bolt Boys –AN fittings; Mr. Metric stainless Allen-head hardware; ATP turbo T-bolt clamps; Rywire Mil-spec engine wire harness and custom radiator; Derale Tornado radiator fans; Spoon Sports thermostat; Spoolin’ Performance custom frount mount water-neck; Billet Specialties filler cap; Summit Racing coolant overflow tank; chrome valve cover
:DDrivetrain 1997 Integra GS-R transmission; Exedy Stage 2 clutch and flywheel
Engine Management P28 ECU w/Hondata S200
Footwork & Chassis Function & Form Type 1 coilovers; DNR Performance rear X-bar; Suspension Techniques rear lower control arms; Benen Industries X-member brace
:)Brakes Wilwood Dynapro 6-piston front brake kit; BP-20 front brake pads, rear brake pads, brake master cylinder and Flexline front brake lines; 2000 EM1 Civic Si rear disc brakes; Earl’s rear stainless steel brake lines; 2000 Civic Type R proportioning valve; brake booster delete
:DWheels & Tires 16x7" Volk Racing TE37 in custom black chrome finish; 205/40-16 Kumho Ecsta AST; Project KICS Neo-Chro extended lug nuts; Skunk2 extended lug studs
:)Exterior JDM Honda Civic Type R front lip, rear bumper, rear lip, doors, thin side moldings, grille and headlights; Bomex roof spoiler and side mirrors; Civic sedan rear door handle conversion; SiR rear glass and tailgate; VIS OEM-style carbon-fiber hood; Custom “San Jose Shark” Teal paint by Franklin Autobody
