Hello every one please let me know which shape is better i dont mean about shape i mean about performnce i like 2003 shape 2d but want to know which one should i buy i have 7lack rupees so want one of them becuase if i go with honda civic there parts are expensive and in my city it will be little difficult to find its parts (dera ismail khan) Thanks waiting for replies
2d vs 2d ?
Generally newer is better. But in Pakistan people always says that older generation was better lol. Get the one which you get in good condition.
Pakistan mein to log har chale jane wali cheez ki us k jane k baad tareef karte hain, like KAL BHI BHUTTO ZINDA THA ... lol
Go for 2003 but 2002 was was really better. The 2003 model had braking issues.
Sent from my Z12 using Tapatalk
The issue was in Xli and Gli. 2.0D have more engine weight had better down force.
2D has more engine braking more weight means harder to stop
suspension and braking system had the same size, and yes its more deadly on the 2.D variant more weight on the same small Xli brake size.
Yahe issue mai nay suna tha k 2003 2d ka brk issue ha 2005 end mai suna ha abs brks ai wo best hain kya 2003 modl ka maza nae? Means brks ka issue ha sach ha ya?
by 2002 you mean corolla e130?
He is referring it as 2003 and by 2002 he means e100.
Right and for me ae100 is much more beautiful than e130.
Brakes ka issue zaroor hai lekin yeh koi aisa issue nai jo aap sort out na kar sako. Agar aap ko 2003 passand hai to go for it and later if you feel brakes are weak then simply upgrade them by changing the discs to larger size and also change the booster.
Disc's aren't the problem...proportional valves are not correct which causes car to slips if you simply install bigger disc's chances of slipping increase future more.
To sir iska koi setting ha? K slip na ho car?
Installing abs unit.
Bhai i have hyundai santro abhi jo haaa isper bhi lag skti abs unit?
It would be an expensive work.
