i have seen many lexus rx 300 in lahore can any one tell me that what is the price of this in (lahore)
Engine 2003 Lexus RX 300
Designation 1MZ-FE
Type Four Cam, 24 Valve V6 with VVT-i
Displacement 3.0 liter 2,995 cc (183 cu. in.)
Bore x Stroke (mm / in.) 87.5 x 83.0 / 3.44 x 3.27
Compression Ratio 10.5:1
Horsepower (SAE) 220 hp @ 5800 rpm
Torque (SAE) 222 ft-lb. @ 4400 rpm
Oil Capacity (liters / quarts, without oil filter) 4.7 L / 5 qts.
Oil Type 5W-30
Cooling System Capacity (liters / qts.) 9.0L / 9.5 qts.
Drivetrain 2003 Lexus RX 300
Layout Front engine, full-time four wheel drive (4WD) or front engine, front wheel drive (2WD)
Transmission 4-speed automatic, electronically controlled transmission (ECT)
Transmission Type U140F (4 x 4) / U140E (4 x 2)
Gear ratios ( :1)
1st 3.938
2nd 2.194
3rd 1.411
4th 1.019
Reverse 3.141
Differential Ratio 3.291 (4 x 4) / 3.080 (4 x 2)
Suspension & Steering 2003 Lexus RX 300
Suspension Front Macpherson strut with cradle-type anti-vibration sub-frame
Rear Macpherson strut with cradle-type anti-vibration sub-frame
Steering Type Power, rack & pinion
Overall Steering Ratio 17.4: 1
Turning Circle (ft.) 41.3
Turns, Lock to Lock 2.6
Brakes 2003 Lexus RX 300
Type Four-wheel power assisted ventilated front brakes, solid rear disc brakes and Anti-lock Braking System (ABS) with Brake Assist (BA)
Disc Diameter (inches) Front 11.3
Rear 11.7
Anti-lock Braking System 4 channel, 4 sensor
Parking Brake Drum
Wheels and Tires 2003 Lexus RX 300
Wheels Wheel size 16 x 6.5 JJ
Type Aluminum alloy
Upgrade wheel type Chrome
Tires Tire size 225/70R16 Mud-and-Snow SR-rated
Tire name Goodyear & Bridgestone (4 x 4), Goodyear (4 x 2)
Spare
Full size tire with alloy wheel
Electrical 2003 Lexus RX 300
Alternator (ampere) 80
Battery capacity (ampere hour) 65
Starter (kW) 1.4
Exterior Dimensions (in.) 2003 Lexus RX 300
Wheelbase 103.0
Overall length 180.3
Overall width 71.5
Overall height (Unloaded) 65.7
Track width Front 61.6
Rear 61.0
Minimum ground clearance 7.7
Approach Angle 28
Departure Angle 23
Breakover Angle 18
Coefficient of Drag (Cd) 0.36
Interior Dimensions (in.) Front Rear
Seating Capacity 5
Head room Standard 39.5 39.2
w/ moonroof 38.1 38.6
Legroom 40.7 36.4
Shoulder Room 57.8 57
Hip Room 55.2 55.2
Interior cargo volume (cu. ft.) Total interior volume 140.6 (cu. ft.)
Cargo Volume (cu. ft.)
(rear seats slid forward - standard measurement) 39.8
rear seats slid back 30.4
rear seats folded down 75.0
Towing 2003 Lexus RX 300
Towing capacity: (requires receiver hitch accessory) 3,500 lbs.
Without towing package: (on 4x2 models) 2,000 lbs.
Vehicle Weight 2003 Lexus RX 300
Curb Weight (lbs.) 3,924 (4x4) / 3,715 (4x2)
GVWR (lbs.) 4,950 (4x4 and 4x2)
Weight Distribution, F / R (%) 57.1 / 42.9 (4x4); 59.0 / 41.0 (4x2)
EPA Fuel Economy (MPG)
2003 Lexus RX 300
Mileage (city / highway) 19 / 23 (4x2)
18 / 22 (4x4)
Fuel Requirement (min.) 87 Octane, Unleaded (92 Octane recommended)
Tank Capacity (liters / gal.) 19.8 gal.
Performance (TMC figures) 2003 Lexus RX 300
0-60 mph acceleration, seconds 8.8 (4 x 4) / 8.5 (4 x 2) - TMC figures
1/4 mile acceleration, seconds
16.6 (4 x 4) / 16.4 (4 x 2) - TMC figures
Top track speed, mph 112 – electronically limited
Redline/maximum rpm 6500 rpm
