Tuning Menu
2004 Maxda RX-8
Owner "Mad" Mike Whiddett
Hometown Auckland, New Zealand
Occupation Pro Drifter For Red Bull/Owner Of CRE8GRAFX
Power 666.6hp/543.8lb-ft
Engine 2000cc Mazda 20B 3-Rotor; RX-8 lightened and balanced rotors, balanced rotating assembly; PPRE apex seals; Hi-RPM modified stationary gears; flowed oil galleries; cross-drilled eccentric shaft; 3-window bearings; full-polished housings and front cover; HKS air intake; PPRE modified Mazda 20B throttle-body and ported/polished 20B intake manifold; (2x) Bosch 044 fuel pumps and (1x) Bosch 040 in-tank lift pump; Turbosmart FRP2000; custom PPRE fuel rail; (6x) 1000cc fuel injectors; (2x) -6 AN braided fuel ines; PPRE surge tank inline fuel cooler; NGK Racing B9EGV trailing spark plug and B10EGV leading spark plug; MSD lead spark plug wires; Bosch HEC ignition coil; Microtech X6 ignitor; HKS T51R SPL turbine; custom PPRE turbo manifold, downpipe, and 3 1/2-inch straight pipe; catalytic converter delete; Turbosmart Pro blow-off valve, 60mm Progate wastegate, and intercooler piping; Redline Performance intercooler; custom oil pan; (2x) Setrab oil cooler; custom Twins Turbo Motorsports oil filter relocation kit; Castrol Edge motor oil; Redline Performance radiator; PPRE radiator hoses; Mazda FD RX-7 radiator fans; Castrol engine coolant; 4-gallon ice/water cell with electric pump and 7 water-sprayers to radiator; Gilmer belt drives; custom Red Bull overflow bottle'
2004 Mazda Rx8 Red Bull Helmet
Drivetrain HKS 5-speed sequential transmission; HKS Pro 2 twin-plate clutch, flywheel, and shift lever; OS-Giken 4:7 1.5-way LSD; Driveshaft Shop axles; Castrol Syntrax transmission fluid
Engine management Microtech LT12; Turbosmart E-Boost 2
Footwork & Chassis TEIN Super Drift coilovers; Mazdaspeed front and rear sway bar; custom front lower control arms, rear lower control arms, rear camber control arms, front toe arms, rear toe arms, uprights, and tie rods; Nolatane and steel bushings; FD RX-7 steering rack; D2 air jack set-up
Brakes Znoelli brake rotors; EBC front brake pads; Silverline rear brake pads; Steel-braided front and rear brake lines; Castrol brake fluids; D2 hydraulic hand brake set-up
Wheels & Tires 18x11'' Weds Kranze Bazreia -36 offset (front); 235/40-18 Falken 615-K; 18x12'' Weds Kranze Bazreia -36 offset w/25mm wheel spacers (rear); 265/35-18 Falken 615-K
2004 Mazda Rx8 Mazda 20B 3Rotor
Exterior Custom Lokey Industries widebody kit and 90mm wide front fenders/100mm wide rear fenders; SARD rear spoiler;BN-Sports hood bonnet; V-LEDS headlights, signal lights, taillights and HID lighting kit; custom NFS/Red Bull livery by CRE8GRAFX
Interior HKS Camp 2 digital dash display; APEX'I EGT gauge; Microtech digital dash; Sparco Evo seats, pedal set, steering wheel, hub, and quick release; Willans safety harnesses; Twins Turbo Motorsports harness bar; HKS shift knob; custom PPRE console; electronic fire depressant system
