Standard/LE SE XLE
Engine 2.4-liter DOHC
16-valve VVT-i
4-cylinder
160 hp [2] @
5,700 rpm
163 lb.-ft. [2] @
4,000 rpm
2.4-liter DOHC
16-valve VVT-i
4-cylinder
160 hp [2] @
5,700 rpm
163 lb.-ft. [2] @
4,000 rpm
2.4-liter DOHC
16-valve VVT-i
4-cylinder
160 hp [2] @
5,700 rpm
163 lb.-ft. [2] @
4,000 rpm
Ignition Electronic, with Toyota Direct Ignition (TDI)
Transmission
5-speed manual overdrive Standard Standard NA
5-speed electronically controlled automatic overdrive with intelligence (ECT-i) Available Available Standard
Drivetrain Front engine, front-wheel drive
Body construction Unitized body with front and rear vibration-dampening sub-frames
Suspension MacPherson strut front suspension with gas-filled shock absorbers and stabilizer bar; dual-link independent MacPherson strut rear suspension with gas-filled shock absorbers and stabilizer bar (SE models add sport-tuned shock absorbers, springs and stabilizer bars; and strut tower brace)
Steering Variable-assist power rack-and-pinion
Turning circle diameter, curb to curb (ft.) 34.8 36.7 36.7
Brakes Power-assisted ventilated front/solid rear disc (power-assisted ventilated front disc/rear drum on LE 4-cylinder)
4-channel 3-sensor Anti-lock Brake System (ABS) with Electronic Brake-force Distribution (EBD) Standard Standard Standard
Vehicle Stability Control (VSC) [3] plus Traction Control (TRAC) and Brake Assist [4] NA on Standard
Available on LE Available Available
Standard/LE SE XLE
Exterior Dimensions (in.)
Overall height, unloaded 58.7 58.7 58.7
Overall width 70.7 70.7 70.7
Overall length 189.2 189.2 189.2
Wheelbase 107.1 107.1 107.1
Ground clearance 5.5 5.9 5.9
Track (front/rear) 60.8/60.4 60.8/60.4 60.8/60.4
Coefficient of drag (Cd) .28 .28 .28
Interior Dimensions front/rear (in.)
Head room 39.2/38.4 39.2/38.4 39.2/38.4
Shoulder room 57.5/56.7 57.5/56.7 57.5/56.7
Hip room 54.4/54.1 54.4/54.1 54.4/54.1
Leg room 41.6/37.8 41.6/37.8 41.6/37.8
Seating capacity 5 5 5
