I have just installed Kabli thermostat valve on my cultus 2007 but its only functioning on higher point (radiator fan is direct). Means needle goes up to the point between mid and high and then drops to mid again. But when I check the radiator pipes they have normal temperature and pressure in them. Engine also doesn't seem to have a very high temperature. Please suggest what could be the reason?
