2007 Meredes-Benz CL63 AMG
Story
Paris, Sep 13, 2006-Mercedes-AMG is unveiling the range-topping version of the new luxury coupe, the CL 63 AMG. Under the bonnet is an AMG 6.3-litre V8 engine that was devel-oped independently and delivers a maximum output of 386 kW/525 hp and 630 Ne-wton metres of peak torque for guaranteed scintillating performance. A glance at the high-tech specification of this exceptional two-door coupe emphatically under-lines its exclusive status: in addition to the unmistakable AMG bodystyling and the AMG sports suspension based on Active Body Control, the AMG high-perfor-mance braking system is also fitted as standard. PRE-SAFE, the anticipatory occupant protection system, is included too and may be supplemented by the addition of both the innovative new PRE-SAFE Brake and DISTRONIC PLUS as an option.
The CL 63 AMG represents the highlight of Mercedes-AMG's 2006 model initia-tive so far, which has encompassed ten brand new high-performance AMG models to date. At the heart of the eight-cylinder flagship model is the AMG 6.3-litre V8 engine.
From its displacement of 6208 cc, the high-revving, naturally aspirated drive unit musters up 386 kW/525 hp at 6800 rpm and generates its peak torque of 630 Ne-wton metres at 5200 rpm. This gives the AMG powerpack a higher power-to-swept-volume and torque ratio than any other naturally aspirated series-produced eight-cylinder engine in the world. The CL 63 AMG is propelled from 0-100 in just 4.6 seconds, with top speed electronically limited to 250 km/h.
Specifications
engine V8
position Front Longitudinal
aspiration Naturally Aspirated
valvetrain DOHC, 4 Valves per Cylinder
fuel feed Fuel Injection
displacement 6208 cc / 378.8 cu in
bore 102.2 mm / 4.02 in
stroke 94.6 mm / 3.72 in
power 391.5 kw / 525 bhp @ 6800 rpm
hp per litre 84.57 bhp per litre
torque 630 nm / 464.7 ft lbs @ 5200 rpm
drive wheels RWD
body / frame Unit Steel
transmission 7-Speed Automatic '7G Tronic'
top speed 250 kph / 155.3 mph
0 - 60 mph 4.6 seconds
