Athletic beauty: The TechArt Widebody based on the Porsche Cayman S doesn’t only offer spectacular design
but also extra driving fun and agility. After the huge success of the Widebody concept for the current Boxster
generation, TechArt Automobildesign now developed a wide body version for the mid-engine coupe.
With the add-on fender flarings on front and rear axle the TechArt Widebody is eight centimeters wider than
the standard car. The front extensions don’t only provide extra room inside the wheel houses but also improve
the deventilation of the heated up air with their integrated wheel-house ventilation. The rear flarings are
equipped with largely dimensioned air ducts to bring fresh air to the centrally placed engine.
Apart from spectacular, sporty design the TechArt designers of course paid attention to optimal aerodynamic efficiency. The TechArt front spoiler bumper reduces the lift at the front axle and improves the cooling of the front brakes with large air ducts. The TechArt rear apron with integrated diffuser rounds out the conversion.
The tail of the car can be alternatively upgraded with the large TechArt GT sport rear wing or a subtle rear spoiler.
Extremely broad wheels and tires make the TechArt Widebody concept for the Boxster complete: Specially for
this wide body version they developed custom-made versions of the one-piece TechArt Formula five spoke
wheel. The front axle is equipped with wheels in size 8.5Jx20, the rear axle is equipped with 12Jx20 wheels.
After extensive test drives, TechArt Automobildesign recommends ContiSportContact 2 high performance tires
in sizes 235/30 ZR 20 front and 305/25 ZR 20 rear for the Widebody. The height-adjustable TechArt sport
suspension is specially set-up for these ultra-wide wheels and tires and the wider track of the car. The coil-over suspension doesn’t only provide an individual damping of the roadster but also lowers the two-seater car by some 25 millimeters. Cayman models with PASM system can be updated with the sporty set up TechArt
VarioPlus coil over sport suspension. This suspension isn’t only adjustable in height but also in damping by a
push on the button inside the cockpit.
TechArt also offers engine tuning for the Widebody. The two watercooled six-cylinder boxer engines can be
upgraded with the TechArt power kits. They each consist of a sport air filter and newly programmed engine
electronics. The result: 15 hp / 11 kW extra power and optimized road performance.
Another performance option is the TechArt increase in displacement from standard 3,387 cm³ to 3,824 cm³.
The increase is facilitated by a bore enlarged to 99 millimeters with the corresponding larger special pistons, and by the installation of a special crankshaft.
The engine conversion further includes sports camshafts. A modified intake manifold with special air filter
system and an aluminum header provide ample combustion air. The perfect interaction of all these components including the fully stainless-steel high-performance exhaust system with high-performance manifolds is orchestrated by new mapping for the engine electronics.
With a maximum power output of 385 hp / 283 kW and a peak torque of 407 Nm the TechArt displacement
engine satisfies both highly sporty minded drivers as well as those pilots who want lots of pulling power from low
engine speed.
Powered by this engine, the mid-engine sports car offers excellent performance: The sprint from 0 - 100 km/h
takes just 4.9 seconds, and with a top speed of 303 km/h the TechArt two-seater easily bests its production
counterpart in this discipline, too.
TechArt offers individual full leather trims in all colors and designs for the Widebody. The range reaches from
completing the ex-works leather trims up to a completely redesigned cockpit with special sports seats and
ergonomically shaped airbag sports steering wheel.
