Subaru Unveils All-New Impreza at the New York International Auto Show
Subaru announced the unveiling of its all new Subaru Impreza at the New York International Auto Show, which will be held from April 6th through 15th, 2007. The third-generation Impreza will hit the market around the world starting this summer.
Developed around the product concept of new, more refined designs for comfort, the latest Impreza incorporates sophisticated styling and rich interior design, roominess and space, and outstanding comfort and utility, while offering a pleasant and safe ride enhanced by Subaru Symmetrical AWD (All-Wheel drive) with the Horizontally-Opposed engine.
Advanced Core Mechanism
The new Impreza showcases a redesigned chassis, body construction and drivetrain, as well as substantially improved overall performance, under the theme “Only Subaru can deliver such attractive performance and values.” It also provides a pleasant ride with ease of handling and integrates performance with advanced safety and environmental considerations.
The newly designed double-wishbone rear suspension effectively absorbs shocks from road surfaces, ensuring high levels of ride comfort and agile handling. The lower center of gravity, enabled by the Boxer engine, has been enhanced by mounting the engine slightly lower in the chassis, thereby further improving stability. Vehicle Dynamics Control (VDC), available on a wider grade range of the Impreza lineup, increases active safety.
Engines and Transmissions
The 2.5-liter Boxer engine features ideal power output characteristics under a practical range of driving speeds through improved mid- to low-end torque. The engine has also been modified to improve emissions and fuel efficiency. The 2.5-liter SOHC normally aspirated engine adopts a new intake port and other design changes that make improved low-end torque and fuel efficiency possible. Improved emissions were realized by a new catalyst system that optimizes catalyst efficiency.
Incorporating a newly designed intake manifold, intercooler and turbocharger, the 2.5-liter DOHC turbocharged engine delivers improved mid to low-end torque and fuel efficiency. Transmissions, both manual and automatic, were modified for faster, more responsive shifting and better maneuverability.
Exterior Design
Refined styling is highlighted by a perfectly proportioned body, well calculated panel curves that reflect light and shadow in harmony, and quality details. Sweeping character lines on both sides express a sense of speed and individuality. A sporty image is underscored by projecting front fenders and rear quarters. Projector lamps, used in the headlights, give a dynamic three-dimensional appearance.
The 2008 Impreza is available in 4-door and 5-door versions.
Interior Design
Spacious and open interior provides comfort and improves visibility. Aluminum-look insets in the center panels and door trim add a sporty feel and airiness. The navigation screen, as well as the vehicle information and audio displays are placed at the top of the dashboard for improved visibility and functionality. High-grade, double-stitched seat fabrics provide a feeling of quality.
Specifications
Engine Type: Turbocharged Flat-4
Displacement cu in (cc): 150 (2457)
Power bhp (kW) at RPM: n.a.
Torque lb-ft (Nm) at RPM: n.a.
Redline at RPM: n.a.
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: n.a.
Driveline: All Wheel Drive
