2009 Suzuki Equator
Performance and Functionality
Built at Nissan’s manufacturing facility in Smyrna, Tenn., the 2009 Equator features a fuel efficient 2.5-liter DOHC inline four with 152 horsepower and 171 lb.-ft. of torque or an optional 4.0-liter, V6 DOHC engine producing a class-leading 261 hp with 281 lb.-ft. of torque. Designed for outstanding performance and durability, the Equator’s V6 engine incorporates an aluminum block with cast iron cylinder liners, forged steel crankshaft, microfinished crankshaft and camshafts, Teflon®-coated pistons, variable valve timing and a silent two-stage timing chain.
The Equator is matched to either a five-speed electronically controlled automatic transmission (I4 and V6) or five-speed manual transmission (I4), and offers an available shift-on-the-fly four-wheel-drive system with an electronically controlled part-time two-speed transfer case. For enhanced off-road capability, the rugged Equator offers a comprehensive off-road traction system, including four-wheel limited slip, electronic locking rear differential, Vehicle Dynamic Control (VDC), hill descent control and hill start assist.
The Equator’s strong, fully boxed frame anchors a long 125.9-inch wheelbase (Extended Cab or Crew Cab/regular bed), enhancing driver and passenger comfort and stability, while its overall length of 205.5 inches (Extended Cab or Crew Cab/regular bed) provides the perfect balance of utility, maneuverability and composure for a midsize pickup truck. The 2009 Equator features an all-steel double-wishbone front suspension and solid axle rear suspension with overslung leaf springs and a long suspension stroke for optimized off-road dynamics. Maximum towing capacity is rated at 6,500 pounds. EPA fuel economy estimates are still preliminary.
Other Equator powertrain components include engine-speed-sensitive power-assisted rack-and-pinion steering for responsiveness and good on-center feel and standard four-wheel disc brakes with Anti-lock Braking System (ABS) and Electronic Brake Force Distribution (EBD). Equator also features a variety of available wheel and tire packages, including 16-inch off-road style wheels with rugged 265/75R16 tires and 17-inch wheels with 265/65R17 tires
Moved to the correct section. [Mod edit]
