2011 Ariel Atom V8
---- Specifications ----
Price £124,850 (about $193,506)
Production 25
Engine 3 liter DOHC V8
Weight 1213 lbs
Aspiration natural
Torque 268 lb-ft
HP 475 hp @ 10,500 rpm
HP/Weight 2.6 lbs per hp
HP/Liter 158.3 hp per liter 1/4 mile
0-62 mph under 2.3 seconds
Top Speed 170 mph
ATOM V8
The Atom V8 is here! After three years of development the latest version of the iconic Ariel Atom is released.
Offering a power to weight ratio previously only found in single seat race cars the Atom V8 brings
unparalleled levels of performance to the driver who wants the ultimate trackday car. Described as the ‘Savile
Row of the Automotive World’ Ariel are taking the handmade and exclusive nature of the ultra high
performance Atom to another level.
To be built in a Limited Edition of just 25 cars the Atom V8 builds on the success of the normally aspirated
and supercharged Honda engined cars, which continue in production alongside the V8. Every car and engine
will be individually numbered and the Atom V8 will be built to suit individual customer requirements as
regards specific use, whether road, track or race. The ultra low volume nature of Ariel’s production means
that the very personal relationship between them and their customers allows for a completely tailor made car.
Said Simon Saunders, Director of Ariel, ‘There are things that can be done in low volume production that the
big manufacturers can’t, won’t or daren’t do so we make a virtue of our size, our skills and the unique
qualities that hand built production can bring to our cars. The Atom V8 demonstrates this right down to
selection of gear ratios for individual use.’
Race specification components are specified throughout the Atom V8 and reflect the extraordinary levels of
performance that the car offers. With over 500bhp available the Atom V8 has a power to weight ratio in
excess of 900bhp per tonne. (Ferrari Enzo 434bhp per tonne, Bugatti Veyron 530bhp per tonne, GP2 single
seater 850bhp per tonne). Race car acceleration and up to 200mph for this ultimate Atom set a new level in
trackday cars.Couple this with full road registration and the Atom V8 truly is a ‘race car with number plates’.
Centre of the Atom V8 is the lightweight 3 litre normally aspirated engine built for Ariel in the USA. Flat plane
crank, forged pistons, chain driven double overhead cam with 4 valves per cylinder and revving to 10,500
rpm, the all alloy and aluminium engine has race car specification throughout. Dry sump lubrication, 8 throttle
bodies with sequential fuel injection and ceramic coated stainless exhaust are all part of the standard
specification and, due to the compact nature of the engine, the installation fits perfectly in to the Atom engine
bay. Each engine is individually tested, signed off and numbered to match the number of the car. Although
producing around double the power of a normally aspirated Atom, the engine has been built and tuned for
drivability. Ariel’s knowledge and close relationship with their customers means that they have an in depth
understanding of the demands on the cars and
not only what customers want but what they need.
Drive is through a Sadev 6 speed sequential race gearbox with adjustable limited slip differential and gearsets
to suit individual customer choice. Gearchange is via a paddle airshift system which makes up-changes in 40
milliseconds and down-changes in 50 milliseconds with the capability of 5 downshifts in less than a second.
The programmable nature of the system allows Ariel to build in safeguards for customers plus have an auto
upAriel Motor Company Limited is registered in the UK. Company Number 6712165 shift and cued down-shift
capability. The ability to carry out flat upshifts without lifting the throttle coupled with 500bhp will give the
Atom V8 the most remarkable acceleration seen in a production vehicle ever.
The inboard pushrod suspension of the standard Atom has been uprated for the V8 with chromoly aerofoil
section wishbones and pushrods coupled with magnesium wheels to reduce unsprung weight. Dampers and
springs have been developed specifically for the Atom V8 and feature lightweight aluminium monotubes with
remote reservoirs giving 3 individual way adjustment (high speed compression, low speed compression,
rebound) which is coupled with a unique 4 way spring stiffness adjuster. For the driver who wants to set the
car up for different uses, different tracks and personal preferences this gives the ultimate adjustability.
New instrumentation and switchgear reflect the track focus of the car. An all new LCD display has shift light,
gear position and programmable functions to show a range of car and engine information, with parameter set
master alarms, for up to 15 channels. Main functions are set to display continuously and the driver can scroll
through information from air, water, oil and gearbox temperatures to fuel, oil and manifold pressures if
required.
Behind the paddle change sits a new panel housing the normal Atom road controls plus tiered switchgear for
adjustable traction and launch controls, wet/dry settings, gearbox settings, LCD display and menu functions.
With data logging facility built in the Atom V8 gives as much, or as little information as the driver needs or
wants.
The unique bronze welded Atom chassis has additional structural braces in the engine compartment and
every V8 chassis will be finished in a special gold powder coat special to the limited edition of 25 cars. Proven
over many years the Atom chassis is not only light and structurally superb but has been proven to give
outstanding levels of occupant protection. Bodywork on the V8 is a mixture of composite woven cloth and
carbon fibre with front and rear adjustable carbon fibre aerofoils as standard. The very high specification of
the Atom V8 and the time spent developing the car on track and Somerset roads gives a result that is ready
to put on any race track in the world and also drivable on the road.
For 25 customers, who are passionate about their driving, this will be the ultimate trackday tool and with 20
cars pre-ordered the Limited Edition will quickly be sold out.
‘Our aim is to put the passion back in to driving and our motto at Ariel is Serious Fun.’ said Simon Saunders,
‘The Atom V8 is one more step to keeping that passion alive and is about as serious as fun gets!’
Ariel Atom V8 - Specification
Engine Type:
Ariel/Hartley 75 degree odd fire V8, offset cam drive
Disp: 3,000 cc
Aluminium alloy block, cylinder head, aluminium cases and sump
Flat plane crank, forged aluminium pistons
Chain drive DOHC 4 valves per cylinder
Power
Road 475 BHP @ 10,500 rpm Torque 363 Nm @ 7,750 rpm
Race 500 BHP @ 10,600 rpm Torque 385 Nm @ 7,750 rpm
Oil System
4 Stage dry sump – 3 scavenge, 1 pressure
12 litre capacity aluminium fabricated tank
Aluminium oil cooler, Pro-lite oil hoses & aluminium fittings
Clutch
Hydraulic184mm Twin organic race disc
Gearbox
6 speed sequential + reverse aluminium alloy casing
Hydraulic clutch
Paddle shift with flat shift capability
Auto shift capability
Gear ratios 1st 13/37
2nd 15/32
3rd 19/32
4th 23/32
5th 21/25
6th 24/25
Final drive 13/56
Adjustable limited slip differential
Fuel system
8 Throttle bodies with sequential port fuel injection
Continuous flow 255 ltrs/hr electric fuel pump
Twin fuel filters
40 litre aluminium fuel tank
Electrical
Electronic coil over plug ignition
DTA S80Pro engine management system with dual map
Data logger output
Adjustable full 4 wheel traction control, Launch control, Wet/dry control
High discharge sealed race battery
Thatcham 2 immobiliser system
Cooling
Pressurised, twin high performance electric coolant pumps
Twin aluminium fabricated radiators
Exhaust
Twin 4 – 1 ceramic coated fabricated exhaust manifolds
Ceramic coated stainless silencer
Catalytic converter
Chassis
Bronze & TIG welded ERW /CDS steel tube
Aluminium bulkheads
Phosphated & powder coated gold finish
Right or left hand drive
Suspension
Double unequal length chromoly aerofoil tube fabricated wishbones
Outboard adjustable race grade rod ends front and rear
Lightweight fabricated uprights front and rear
Adjustable chromoly aerofoil tube pushrods front and rear
Aluminium bell cranks front and rear, needle roller bearings
Inboard 3 way adjustable monotube dampers with remote reservoirs
4 way adjustable alloy steel springs
Steering
Rack and pinion cast alloy steering rack 1.7 turns lock to lock
Collapsible offset steering column
Adjustable inboard joint and outboard rod ends
300mm race suede covered steering wheel
Braking
Front: 290mm ventilated crescent grooved discs, 4 piston calipers
Rear: 290mm ventilated crescent grooved discs, 4 piston calipers
Aluminium racing pedal box
Twin master cylinders adjustable front/rear brake bias
Parking brake
Wheels
Front: 7Jx15 5 spoke magnesium
Rear: 8Jx16 5 spoke magnesium
Tyres
Front: 205/50R15
Rear 245/45R16
Body
Carbon fibre, woven cloth composite mix
Carbon fibre aerofoil package front and rear
Seating
Twin seat unit composite woven cloth, 5 position adjustment
3” FIA Approved six point quick release full harnesses
Instruments
LCD display CAN interface to engine management system
Gearshift lights, gear position indicator, warning lights
Selectable display for speed, rpm, fuel level, fuel pressure, voltage,
water temperature, oil pressure, oil temperature, gearbox temperature,
airflow, manifold pressure, air temperature.
Parameter master alarm for all channels
Dimensions
Length 3695 Width 1848
Height 1195 Wheelbase 2345
Weight
550kg
Performance
0-60mph (100kph) less than 2.3 seconds (e)
0-100mph (160kph) less than 5.4 seconds (e)
Top speed 170mph (275kph) road 200mph (320kph) race
Price
£124,850.00 plus VAT
