The interior is similar to HRV. It is all about how Honda has decided to localize it. HACPL is not brainless... GN1 and GM6 are chassis codes. Sure the chassis is completely different, but there is no reason why Honda would not put a newer interior inside the GM6?
If you think about it from a cost perspective, it makes a lot of sense. The machines for chassis assembly are significantly more expensive than the local vendors which make the interior in Pakistan. The exterior can be 6th gen but the interior can definitely be revamped or elements of a newer gen can certainly be put in there to make it a much more lucrative choice for consumers...
The point is this: interiors need not be specific to a single generation. Crossing of elements between generations can help cut down the cost of bringing the car to the market and increase sales.
@fazalwahab11375 I would recommend you wait until the car comes out and then start smearing a brand that does NOT have a history of misleading advertisement. IF you can produce evidence of malicious intent and false advertisement here, you are more than welcome to present it. Don't just say stuff because you 'THINK' it is not true.
