Back view camera at night is better than civic x. navigation is also with android 9, don't sure about ram as it's not showing it in system info but response is good, no lag.Internal memory is 16GB.
are there no more details in the instruction manual? maybe a model number? i messaged the trackingworld facebook page for some details. lets see what they reply
Same, I also send them a message. Detail manual only have functions and options description.. nothing about hardware and mobile sim connectivity.
maybe try asking your dealership too? the civic model on the tracking world website says it has support for tpms. that would be great if i can get tire pressure on the unit too
This is my 1.5 Aspire CVT's fuel average. Filled my tank for the second time (first being right after I took delivery). Car was driven mostly in bumper to bumper traffic with AC without econ mode.Hopefully avg will improve after first oil change
I was hoping they will provide a sim slot close to SD card or a separate cable.
it will be pretty stupid if we would need to remove the unit to install the sim in it
If there is a SIM slot, its IMEI number will require PTA approval? otherwise it will be blocked in 2 months
if it has a SIM, then it must be PTA approved, otherwise they cannot import these units.
@umfa85 Can you please check your air press. My driver side one is a bit loose and the double tape is coming off
It's there by default or after market?
In Aspire variants air press come installed from the factory it that's what you're inquiring about
I'm facing same issue on both front driver and passenger side airpress. They have used some daysi doubleside tape..
@ghufran.tariq brother, there is one beep, similar to some text message when ever I start car and ready for drive.. do you know from where it comes and what is its purpose.
@umfa85 Bhai can you please record that beep as I don't get one when I start the car. If it's like a text message maybe it's a notification sound from the android panel.Also, have you opened the notification drawer to see if there are any notifications?
beep
Yes you were right, that Beep was from notification. it only gives beep when connected to wifi. mostly from Gmail
FOR INFO ONLY
_One of my friend took "Fog Lights" & "Back Camera" option in 1.2 CVT & it really worth._
Back camera option in 1.2 cvt has nice resolution as well.
