Squeaking can happen due multiple factors like failed brake pads or dirt or lack of lubrication. Get your brakes serviced. If the brake pads are fine, make sure you get the brake pads, rotor sanded and cleaned. Clean and lubricate the caliper pins and pad clips. If brake service done properly, hopefully that will solve the issue.
Check this image as reference so you could understand the parts I mentioned above
