Yeah thatโs not ideal. Let us know if it improves or you get it to fix. Thanks for taking one for the team. ๐ซก
My tail light cover has broken. Don't know how what or when hit it. There is a circles broken out.
Does Honda provide only the original cover? Or should I just get locally replaced. The local shops do a pretty bad job with the glue and all. I mean I know it works fine but would prefer original
Covers will fade away ina while.
If under warranty get a new light. If it's just cracks put elfy to close holes else water will go in.
If you have to get a new light, try the aftermarket ones for a change.
unfortunately its like a circle broke off and fell. i cant imagine how anything can hit it for it to break like that.
the only thing i can think of is like a ball hitting it.
Repair shops can cut it a square and fit a peace or repair.
But that will show separately. If you need contact for light repair guy.
Let me know, Dha phase 2, all magazine line people have come here. I know a guy who I get repairs done from.
sure do let know
Shams 0310-2626245
Question: What do you do with 200ml remaining oil after oil change? I have around 1litre overall saved from previous oil changes.
Use it for the house Generator Oil Change.
Keep on rotating new 200 ml on each oil change and after couple of years. Youโll get one oil change free
But will the open oil not get soiled after few months/years in the open?
No.. whenever you go for oil change, keep last time spared oil bottle with you & pour that oil (which might be 200 or 800 or 1400 ml) first in engine and then tell the mechanic to open new oil bottle & top up as per oil change recommendations of aspire 3.6 L with oil filter and 3.4 L without oil filter.
Well my infotainment is showing blue-tooth connectivity issues. Rebooting doesn't even seem to fix it. Will take it to the dealership next week.
Tint shop in Pindi which is good in quality and rate
Any more updates?Is it worth buying?
No. Atleast not worth on the wireless. It's tooo laggy.
Will try again with the wired setup and update on the group.
ab to sara mix kar dia have last 2 years ka. can I sell it?
i seem to remember someone here mentioned that the update for the tracking world head unit was now available to install ourselves instead of getting an appointment with the tracking world guy.
Do i remember that correctly? if yes then how do we get the update file
I have the same variant. Install speakers in rear door from dealership and adjust the equalizer in the head unit. I wouldn't say it will be out of this world but it's really great. At least better than GLI (Comparing with GLI because I have both and GLI's sound system is hideous).
