This is how it arrives from China: (I am selling on first come first serve basis and have around 40 pieces of 150 and few pieces of 125 and only one piece of 250 left)
With Complete kit and accessories to just Fit and Go! Bolt on for Ravi Paiggio Engine Swap, Deluxe and GS also fit-able with help of denter.
Accessories and all Kit :
Radiator
A look inside the box:
150cc Engine:
250CC Engine:
Testing the engine before putting into bike
Bike receiving a 250 Engine.. Fitting Like a Piece of Cake ...
BOLT TO BOLT Fitting on Ravi Paiggio :
Details:
These are A+ Quality engines whos adopt following advanced features:
2.Improvements about engines:
(1)It has Special Type of Clutch Plate with Special Type of Oil-resistant Rubber and Colophony to prolong the using life of Clutch plate 20%more than normal Clutch Plate. (Six pole and six patch, normally four pole and five patch).
(2)Uses Newly Designed Piston―― Its a Even-Pottery-plated Piston.
Main advantages as followed:
A.Much lighter and more lubricative. Excellent performance in reducing the friction and optimizing the power output.
B.Improve burning environment of the mixed gas and strengthen the torque at lower and middle speed.
C.Newly advanced manufacturing techniques have been adopted for high quality piston. It has excellent performance in preventing heat leak into the bottom in order to prolong the using life of the piston and piston rings.
(3)Uses high tech, steal hard Special Type of Piston Ring (CRY) with two special metals: Cr & Nb to enforce the intensity.
(4)Contains double-modulus Main Shaft and double-modulus Counter-shaft to enhance the gears, to enlarge the transmission ratio, to strengthen the anti-wallop ability. It has excellent performance in prolonging the using life of engine.
Do note I have shared own taken pictures and also some close ups from internet for giving you better details.
Please feel free to contact personal message only, PM is the best way to communicate.
I will try my best to locate any motor which can be feasible to your ride.
Suitable For : PAIGGIO STORM, CG 125, CG 125 Deluxe, China 125, CHINA Deluxe, GS150 ...
