[QUOTE=vickytulla;4377580]The 250cc engine belongs to this Bike :
and these are the specs (not to mention it has more torque the Kawasaki KLX)
Motorcycle model: LF250 (dual sports)
Dimension ((L?B?H mm):2200*860*1240
Wheel base (mm):1420
Min.Ground Clearance (mm): 220
Dry Weight:148kg
Height Of Seat (mm): 870
Fuel Tank Capacity(L): 12
Engine Type Single-cylinder, water-cooled,four-stroke
Engine model:250-2
Bore?Stroke: 72mm*61.2mm
Displacement: 249.2ml
Maximum Net Power 13.2kw/6000/min ~15.8kw/7500/min
Maximum Torque:19.4N.m/5500r/min
Clutch: Wet multi-plate
Lubrication: Pressure/splash
Start: Electric start
Ignition:.T.C.I - 3 phased
Transmission: 5 gear
Max. Speed (km/h): >100km/h
Economical Fuel Consumption (l/100km): ≤2.4L/100km
Front Type Size and Air Pressure: 3.75-17/200KPa
Rear Type Size and Air Pressure: 4.10-17/225KPa
Climbing Ability (?): ≥23?
Exhaust Index: CO≤3.8%;HC≤800ppm
Start Performance: ≤15s
Braking system (front/rear): disk/drum or disk on both
Brake Performance: ≤7m/30km/h
It says here that the max speed is just above 100km/h, which I guess is not to be confused with the engine's actual performance. This bike weighs 148kg (on empty tank) and then I suppose the gearratio's/sprockets are set to allow for alooot of acelleration, since it's a dirt/terrain bike it needs that, am I right?
When installing this on street/roadbikes such as most of the one's in Pak, one could adjust the gearratio's to allow for comfortable 140km/h+ speeds? How does it work?
The average mechanic doesn't know about gearratio's he's only bothered with fixing bikes which won't run ......so confusing...
