Assalam-O-alaikum! I have this old 1993 Toyota Crown 2jzge engine with a mechanical fan. Is there any way I could convert it to an electrical fan. Thanks
why??
the clutched mechanical fan is better than the electric. It blows a collosal amount of air.
Sir in my w202 the fan keeps working all the time..How to fix it?? New clutch?
I think for slight better fuel economy
It will run all time the problem would occur if it run at same speed that of engine (sticky clucth)
Yes it's running at the same speed as of the engine.I don't know why MB has put 3 gaint fans on my car Engine se zaida awaz fans ki ha
Then you need new clutch for it
does the clutch let go after 30 seconds from starting? - if mechanical clutch
can you snap a picture of it, do you have the electric clutch?
Just completed the conversion. I'll try to post some pics tomorrow.
Can't make out anything. Please post clearer pics.
Sent using Curiosity's onboard communications sytem.
