Salaam brothers
2zzge in ee90 corolla since 2018
Normal saada tune done 2 years ago, stock ecu with fpr, custom headers, air n take and downpipe (2.7") and power pro exhaust.
I remember problem started when I changed the car's custom downpipe of 2.7" to 2.2" and exhaust.
Problem is misfire, shaky jerky jolty, sometimes on idle and at times low rpms. On idle one moment its fine other moment the rpm drops from 800 to 500, starts shaking, then to 200 and shuts off, this time its emitting black smoke from exhaust, bad smell and very poor mileage, dropped to half what it was giving me earlier.
Problem started 5 months back with a tiny/unnoticeable misfire on motorway on 2500 rpm. I frequently drive on low rpms. Another misfire after a week. Couple of misfires in a week, went to couple misfires per day, then the car was not actually moving one day, too much misfires, car was too shaky and jolty (jhatke) when I pressed the pedal, in neutral gear it use to shake and shut off. On higher rpms it would be somehow moving, but not quite rough and shaky .
Went to electrician, changed AFM sensor, he changed it form type C to a normal without alphabet. Car was fine two three days, then back again to misfire. Still the normal AFM worked better than the type C till date, I put three other type C sensors but that didn't work.
Checked afm sensor wiring, battery to fuse box wiring, changed air filter, cleaned butterfly, checked injectors and cleaned them for any blockage, checked plugs, checked coils, 02 sensor, changed fuel pump (didn't wanted to).
(everything checked and changed was not in one go)
The car used to get fine a day or two after a component was cleaned, checked or changed, but it would get to misfire again after two three days.
Checked and cleared exhaust manifold leaks, recently changed fpr the old one didn't properly maintained pressure, no improvement even after the change.
Please advise, how can I get it smooth (no misfires) and improve mileage (no black smoke), without visiting the tuner to remap on stock or re-tune (someone advised me to that).
