My car is se saloon which has 3zz auto transmission. Due to bad fuel average I was thinking to change it with 1 nz which is 1.5.
Is it a wise decision or not ?
Sent from my HTC One_E8 dual sim using PW Forums mobile app
Few years back I swapped a 1zzfe into my Se Saloon. Great results
Auto or Manual ? I am more concerned in fuel average
But yeah there are other methods to improve your current mileage. Have you tried throttle body service, fuel injector cleaning and new spark plugs?
Auto. Fuel average remained the same almost but the power was a totally different level, with a fresh JDM 1.8
Yeah all done.. average is 8 in city
This is a good average, keeping in mind that it has aged and deteriorated.
True. What about 1nz
Can't say much about the 1NZ, but if your current setup isn't acting up then I'd suggest you to not go for a swap.
Hmm yes I know swap has many issues
What about ECU will it be changed and also mounts
OK. Please confirm about one thing more.. 1nz injectors can fit in to 3zz as someone told me to try this for fuel average
@syncview. Please update
Waiting for response please help
Sir, if problem is only wid fuel average and not wid the mechanical side of engine than i would suggest NOT to go for a swap....a swapped 1NZ is most likely to give you almost the same average (if not properly swapped)....and you are not even factoring in the cost of swap and trouble-shooting
you can save the cost of swap/engine and still be happy wid bad average....
Thanks.. Please guide someone asked me to install 1nz injectors in 3zz engine.
Will they fit and is it a good idea?
Sent from my LG-D851 using PW Forums mobile app
