Salam pws... just another project.In the mean while the parts arrive. Im repairing the wiring harness.This engine was previously used by my cousin and with jugari wiring. With vvt solenoid directly connected to ignition. Might that be the culprit of engine wreck.Well I need help in wiring harness. Firstly need a ecu pinout diagram. Wish it had a printed one..
The ecu.What is this component in the mount were the coil and ignitor are located.?
Sent To You On PM
Kicking Inn VVT Directly Will Not Do Any Good....!
Internet is your friend
20V Swap Wiring Reference « [QR]GARAGE
2nd Diagram Is Of ST....Will Not Work On BT...
3rd Is General Wiring Ref Of 20v
4th Is For AE86 RWD Custom Wiring Setup
Well 25% done on the intake manifold side. Just put it together on the engine for perfect measures now rough taping it..
The throttle position sensor has 4 wires. And the blue wire is not hooked up in the ecu connector? What to do guys?
Were is the blue wire supposed to hookup? Its left out.
What ac compressor are you using? I dont have any. And what pins are connected in it? It got 6..
were do you connect the tachometer wire ? coil , ignitor ? or the ECu?
Tachometer..... You Can Get TACHo Signals From IGF Wire On ECU
Just Hook Up All Your Sensors And Its Wires And Left The Rest Of Wires....Not Every Wire Is For For Your Need....
the blue wire is from the throttle position sensor, and the rpm fro igf the Ignitor feed back right ??
How do you trick the ecu for a.c idle up? Without the amplifier.. and thou I dont have the amplifier. And the ac compressor is not the original ac compressor of the blacktop.
ELS Pins Can Be Used To Trick Idle.....
Impressive ... will gonna do that... but still one wire is killing me the wire from tps which is not hooked up.. its blue.. im sort of a freak guy. I hate extra wires. And thou I deleted many wires from the loom.
is your Air Conditioning working?are you using 4AFE's A/C?
Salaam!What happened to your project?
