Thanks dear. Are these available brand new for motorcycles.
Yesterday I called this guy. He has installed Volta dry battery 4ah in his m-cycle and told that he has used stock casing.
I will look for the one you mentioned or the Volta.
Plz also guide me a little bit about battery charging system.
1) As factory default battery is 2.5ah, so stock bulb in cg is of 25 watts. If I install battery of 5ah or 4ah, and 60 or 50 or 35 watts headlight bulb, would they get enough current from generator/alternator and will I get better light.
2) Any wiring heating issue or stock light heating issue.
3) Would battery be fully charged. I daily ride total of 24kms morning and in the evening.
4) What necessary adjustments/alterations to be done if I do it myself.
